Polishing
  • Sandy H
    • Sep 2006
    • 118
    • Toronto Ontario Canada
    Polishing
    Hi
    I am wondering does the clutch plate have a clear coat on it?
    I am using 400 wet sand paper to clean it up,then using never dull to brighten it up.
    What about the actual aluminum engine?
    I know I can't sand that. It has been sitting for 7 yrs.
    This summer I got it up and running.
    Now it's time to make her pretty.
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    Hey Sandy , not sure about the 400 grit paper. You might want to try something finer and might be tuff getting into the little knooks and crannies with sand paper.
    I am doing the same this winter to mine and I was thinking about using some fine stainless steel wool with some polishing compound maybe a #0000 to start.The clear coat is all but gone from my covers.
    I am also thinking about getting the engine case powder coated in a nice gloss black finish.
    BDF Special
      Yup... 400 grit is pretty rough. While many graduate from rougher to a finer size, most usually end up wet sanding with a 2000 grit or finer, then followed by a polish of some sort. My personal favorite is Simichrome since it can be used on everything including the headers without turning colors from the heat.
      Some people use the steel wool. I never have, but I have heard of fine pieces of steel being left behind embedded in the aluminum and rusting.
      Glad everything is running good and you are starting to clean it up. Take some before and after pics for us... and yourself!
      • TERJE ANDERSEN
        • Aug 2003
        • 106
        • BERGEN,NORWAY
        Polishing
        Hello ! I am not an expert on polishing ,but this works well for me: take off all engine covers you want to shine up. If they never have been off the bike before - they will still have some of the factory clear coating on them. If so: remove the clear coating with paint remover. Wash with water.
        The next I do is to use my 11500 rpm grinder (nota Dremel type - I have a bigger machine) to polish with what we call polishing cheese here in Norway. I dont know the name you use on this in USA, but I am sure yo will find it in hardware/tool stores. (Weight of each "brick" with polishing cheese is about 4lbs here.)There are different products for different metals. Use one for aluminium. It will take some time to polish each cover,but when you are finished with them they will look like mirrors !
        I have not clear coated my covers because I think they look better without clear coating. But ofcourse you will have to polish them from time to time. If you get water on the covers the aluminium will soon need a bit TLC.
        TERJE
        `79SF
        `80SG x 2
        `80LG x 2
        `81SH
        `82XJ1100J
        `83CB1000 CUSTOM
        `79WIFE
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Polishing Aluminum
          Go here for more info...
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • brucealmighty
            • Jun 2007
            • 76
            • Connecticut, USA
            I've been told to never use steel wool on aluminum. Strands of the steel will become imbedded in the aluminum and then rust, making the whole thing look a lot worse then when you started. Brass wool is okay.
            The life of a Repo Man is always intense.
            • Sandy H
              • Sep 2006
              • 118
              polishing
              I am using 400 sand paper to get off the grit.After all it has been sitting for 7 yrs.
              I am going to use 2000 after then put a polish(Mothers)
              I am going to try and get some pics for all.
              Lots of elbow grease but it is starting to look pretty good.
              I am also using a dremal as well.
              Where Ever You Go.
              There You Are.
              '82'xj1100j Maxim
              • HobbyMan
                MeatHead Idiot "GURU"
                • 1801
                • Colleyville, TX
                I would advise against 400. That is pretty rough. Usually it pays of to start out with a little finer grade and put a little more work into it. For this aluminum, I usually don't go any heavier than 800. Then I go to 1000 wetsand and then 2000 wetsand followed up by a polish. I havn't done a lot of work with this but with what I have done, the results are amazing.
                Acta Non Verba
                  Darn ol' carbon-steel embedment
                  When the contractors were welding up the calandria of our WR1 reactor the inspectors found rust streaks on the stainless steel after the light water leak test. Turns out one of the welders was still wearing his old-fashioned hobnail boots as he walked about inside the thing during construction.
