I did a search, but didn't find my answer. Are the butterfly shaft seals anything special, or can I just use vitron O-rings? If they are different, does anyone know of a good source for them?
I made the mistake of buying someone's fully disassembled, basket case carbs off ebay. Now they need major cleaning, full rebuild, and replacement of nearly every screw. Someone has obviously never heard of heat and penetrating oil
On the plus side I have more info for the rubber plug anomaly. Unless the floats have been replaced, this 80's set has PLASTIC floats and the drilled passage from the main to pilot that requires the rubber plug.
Man, 1980 must have been a crazy year for Yamaha and Mikuni
