I have oil dripping out of the bottom of the part where the drive shaft connects to the rear axle. Never noticed this until today. Anything I can do?
Leak from rear axle...
Tags: None
sorry... take it apart and have a look"a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400 -
Do you mean where the swing arm on the shaft side meets the final drive unit? If so what color is the oil?
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
Hey Darrek,
Do you mean hear where the 4 bolt/studs are on the FINAL DRIVE(rear axle drive assembly)? This is a 750, but same thing!
Could be a damaged seal in the final drive assembly? BUT, I would also be ready to check the MIDDLE DRIVE, and the rubber boot covering the U-joint. I know the boot is supposed to have hole at the bottom to allow oil/water to drain out, but can get clogged, and then IF the middle gear seal goes, it can leak out the back, and possibly down the hollow driveshaft swingarm and finally out that junction.....but most likely not!?
However, it's leaking at the actual BOTTOM of the Final Drive, could be the drain plug, but also the large O-ring that seals the wheel hub.
T.C.T. C. Gresham
Its leaking from the bolt that goes in the hole with the arrow pointing to it.1979 Eleven Special - 26,000 miles.Comment
check level, or change gear old and teflon tape the leaky bolt."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400Comment
change gear old???? maybe im just reading it wrong.
edit: or did you mean gear oil?1979 Eleven Special - 26,000 miles.Comment
sorry, yes gear oil"a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
so youre saying to drain the old oil by taking out that bolt, wrap the bolt in that teflon tape and reinstall and then reoil it?1979 Eleven Special - 26,000 miles.Comment
yes if in fact the leak is coming from that bolt only you can tell, if not then you have trace the source of the leak but this seems plauseable.
if this is the case, the bolt has to come out for repairs anyways you might as well change the gear oil, drain it,
stop and read this
but first!!!
be able to remove the fill plug, if not take a ride to heat up the rear dirve this will expand the housing a tad from the frozen fill bolt, uxe a right sized allen head and remove the bolt, you must do this first, cause if you can't take out the fill plug, you are up crapcreek, if you drain the oil first, get it??Last edited by mason79; 11-12-2007, 02:04 PM."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
lol... sounds like that happened to someone before.. good thing you told me too... i live in teh cold neck of the woods.1979 Eleven Special - 26,000 miles.Comment
i don't know when you got the bike but, while you are back there take the rear drive off inspect and grease the spline s to the wheel hub and the splines to the drive shaft, this is mandatory work. but do the oil change first,
remember the top cap is NOT the fill plug so don't go wrenching that off that is the vent cap
the fill plug is the centre most right plug capped with a plastic insert, remove the insert.
with the drive off make sure you are right side up on the drive otherwise you will leak oil fromt the vent hole.Last edited by mason79; 11-12-2007, 02:17 PM."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
do you reccomend doing this before i put it away for the winter??
oh and happy 1111th post.1979 Eleven Special - 26,000 miles.Comment
it's up to you , if you are obsessive compulsive like me then it's a no brainer, if you could care less then that's a no brainer, or you could be somebody in between. if you need to ride then ...hello...
heck the winter, i wouldn't know anything about that, never been there or done it, is a good time to do all the work and then some right or wrong?Last edited by mason79; 11-12-2007, 03:20 PM."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
Hi Firecracker,
the fill plugs on the axle housing and on the middle gear housing jam in there for a pastime. The axle plug at least can be removed more easily if you unbolt the unit to grease the spline. (Note that the grease nipple on the outside cannot possibly put the grease where it needs to be.) Then you can get at it to bear straight down on the Allen-socket so it won't cam out rather than turn. I fixed both of mine by brazing a hex nut on top of the bastards so they'll undo with a wrench.Fred Hill, S'toon
"The Flying Pumpkin"Comment
