Hi all! I noticed a set of nice large washers and a nice large dowell pin in a plastic bag that came with my XS1100 from the previous owner. The washers looked like the ones that go under the valve springs, and the dowel looked like it belonged between the head and the block....seeing no reason why anyone would replace just one nice dowell and all new valve spring washers I assumed that they were just the leftover pieces from when the PO put the head on. I got the bike not runnig, but was told that the valve seals have been done and that the only thing left was to adjust the valves, put the carbs on, and that was it before the bike would run..... I had my doubts, and pulled the head off. Sure enough those parts were missing in my motor, on top of that the valve seals were ready to slide off, head gasket center section was in the cam chain well, and 3 inside head nuts were loose!
Anyway, now that I am here are there any cheap/fast and proven mods that I could do? The bike is a 1979 SG. Should I try to get a later head from Ebay, and use my cams? Big bore? Replace just the rings with filed .25 over in a stock bore? (the bores look perfect and the bike has very few miles) Quick port job? shave the head? Ceramic coat the combustion chambers/exhaust ports
Please throw ideas at what are the possibilities. Also, would anyone know where would be a good place to get the replacement rings? I understand that stock size is impossible to find.
Last XS I had in 1997 (the last time I was active on this list I think
) there was definite lack power....and now is my chance!
thank you all in advance
--Nick
?Please throw ideas at what are the possibilities. Also, would anyone know where would be a good place to get the replacement rings? I understand that stock size is impossible to find.
) there was definite lack power....and now is my chance!thank you all in advance
--Nick
