I noticed that the brass IM (Idle Mixture) screw covers on my 80G has a small hole in them, (makes drilling and removing easier). The pertinent question is, are the holes necessary to allow air into the mixture? I noticed that the replacement covers on Mikes has holes in them too.
I know that it has been said that you need not replace those caps when doing the deed, but I was going to put the extracted brass caps back in the holes and seal the drill hole with hot glue to keep out dirt after synching, but if the "Air Hole" is necessary I will not do it.
