I've read Ken Talbot's tech tip on a rig for setting float height. My 79 doesn't have bleeder valve in bottom of float bowl. ? Am I stuck with tipping over carb and measuring the float height with a reference on gasket surface? This doesn't seem very accurate for 4 carbs.
On K. Talbot's rig, is fuel introduced to each carb individually? Like maybe a 90 where the "t" between 2 carbs usually goes? I'm probably having a "senior" moment here, and asking dumb questions, but........ Has anyone came up with a bleeder valve for early xs1100's?, and is the level in the clear tubing 3 cm below bowl mating surface?..I mean how full is "full" when the float and the needle do their jobs? (I think I just heard something go over my head). Heh.
