XJ 1100 OEM fuse slot names
  • Filter
  • XJ 1100 OEM fuse slot names
    Hi guys, haven't been on the site for a while but its so great
    to know its still here.
    I'm having a problem with one fuse in my converted T.C.
    fuse panel. It has been fine up till a few weeks ago.
    I was merging into a major thourgh fare and my bike died-
    no signal lights, ignition nothing. I coasted until I was out of
    danger of being run over. I pulled the side cover off and found
    the 20 amp fuse that would be no. 4 starting from the front back
    blown. I failed to mention that when I got in a safe area I tried
    to restart the bike. Emergency flashers worked but no starter.
    I replaced the 20 amp fuse and it fired right up. When I got home I removed the side cover again to examine that fuse again--
    it was blown, but my starter would respond to the button. I
    completely have that fuse out and the starter and all electrical
    functions work.
    I looked in my factory manual and there isn't any picture of
    the OEM fuse box and what each space is for.
    Does any one have any suggestions as to what might be
    occuring?
    Thanks
    dodjh
    Semper Fidelis to my brothers serving on foreign hostile soil
  • #2
    Hey Dodjh,
    I found this info on the wiring diagram, it doesn't say which fuse is near the front vs. back, but it does provide the associated wire colors, and it does tell which circuit they protect!
    The Wiring Diagram shows
    Tail=10A L/L =blue
    Head=10A Br/R-Y
    Signal=20A Br/Br
    Ignition=10A Wires R-W/Br
    You'll notice that the 20A fuse is NOT #4, but #3, the turn signals!
    However, there is another smaller MAIN fuse block under the LEFT side cover area, that you may NOT be aware of? And it could be causing problems? Or you might have a faulty ignition switch?
    Or...as Jerry has recently stated in another recent post, the sidestand switch could be going bad which could kill the bike. He posted a bypass description in it, a quick search should reveal it!
    BTW, what ever happened with your increased lighting quest?? Did you get the 80/100 watt bulb, or the clear lens conversion?
    Just curious, and wanting to add some info/feedback to folks.
    • #3
      XJ 1100 fuse slots
      Hey T.C.
      You are so faithfull to respond to a SOS. I don't know why a 20
      is in where the 10 should be. This happened once before when
      I was trying to crank the bike. No neutral light or starter
      engaging. After discovering a blown fuse I replaced it with a
      new one and again it shorted out the fuse. The left side where
      the wires run between the motor and exhaust pipe was the first
      place I checked. I wiggled and moved them away from the
      exhaust pipe---then put a new fuse in and it didn't blow.
      The incident I mentioned in the thread happened after that.
      I will check ignition, sidestand and Jerrys' by-passing the
      side stand.
      Thanks for remembering our lighting discussions. I did put
      a clear lens conversion but not the 80/100 yet. The conversion
      change was very obvious and provided greater road light. I was
      attending some night courses at a local university and drove the
      XJ as much as weather permitting. It is good hearing from you,
      your advice is so valuable as is your willingness to take on
      someone elses problems.
      Till the next time,
      dodjh
      • #4
        XJ 1100 OEM fuse slots
        So far I have been unsuccesfull in locating Jerry's sidestand
        switch by pass. Is there a specific word to enter besides
        sidestand by pass switch?
        dodjh
        • #5
          Is this it?
          http://www.xs11.com/forum/showthread...threadid=15570
          KW
          1982 XJ1100J
          1980 XS850SG
          • #6
            XJ OEM fuse slots
            Kevin W,
            That is the thread T.C. was referring to. Thank you for finding
            and setting up a easy way I could retrieve it.
            Sincerely
            dodjh
