Hello all! Been awhile since I've had an XS, but I picked up a very clean '78 Standard this weekend. It is mostly stock with the exception of Mac pipes (2-into-1's).
The bike starts very easy, but I am finding it is sticking at about 3K idle. It is not the idle setting as it will go down to a more normal idle (About 1100rpm) if I use the gears to slow down below the 3K idle. I am thinking it might be a bad vaccuum line, but would like some advice. There is a bit of cracking on the boots, but I sprayed them while the bike was running at a low idle and did not get any change in the idle.
Any thoughts?
Thank you! I'll post some photo's soon...it is a very, very clean bike with fairing and "samsonite" luggage!
Any thoughts?
The gas diminishes very quickly, and doesn't collect on parts like a liquid!
