My Latest Mod
  • 81xsproject
    • 3185
    • Fortuna, CA
    My Latest Mod
    Ever since I installed the Hydro-clutch, I have wanted an FJ brake master to match the nice looking clutch master. I finally got it done yesterday and love the way it looks. Notice in the bottom pic how much smaller the profile of the FJ is. Granted the old one is being held very slightly closer, but there really is THAT much difference in size. For a visual reference, the old one would be sticking over the tach face by about a half inch.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "Looks nice...."
    Now... just replace those screws(But you know this)
    Put some grease or anti-sieze on the threads, first.
    I kept a supply of those screws at the shop, as on older bikes, would often have to drill them out as they tend to electro/chemi-bond themselves in place.
    • AlanB
      • Oct 2006
      • 705
      • Scotland
      Hi 81XS,
      Looks good...... But does it work?
      All Jap master cylinders have the piston diameter cast into them.... many in inch sizes.
      XS11 should be 11/16" which is almost unique to the XS. The FJ masters I have here are all 5/8"...... as are almost all twin-disc masters. Single-disc versions are usually 7/8". Late vehicles do use metric equivalents.
      The reduced piston diameter will need extra lever travel to get the brakes to work. I tried this conversion and found it unacceptable. The lever came too close to the bar. If you have stainless lines, it may be OK.
      I now have modern four-pot calipers, Steel lines........ and a 5/8 master.
      AlanB
      If it ain't broke, modify it!
      • 81xsproject
        • 3185
        • Fortuna, CA
        Good info, thanXS Alan. I haven't gotten to take it for a spin yet. If the stopping power isn't there, I will have to go to something else. I really like the size of the unit though. Does anyone know the the partsnmore master compares?
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          Hey Jessie,
          The PNM master Cyl. works very well, provided you get the one that is the 16mm bore size for 2 calipers!
          I'll tell you that I have a smaller MC from what is probably an XJ1100 designed for 1 caliper. When I had the OEM lines on it, it didn't provide enough pressure without having to pull the handle almost all the way to the grip like Alan eluded to. But once I put on the SS lines, it was more than adequate, and I don't have to squeeze it very far to activate the brakes, and I think it actually gives me a better feel! YMMV!
          • pggg
            • 1609
            • NZ
            81, it looks good with those twin FJ cylinders, I wouldn't change them, if the braking is too spongy I'd go steel lines instead
              • 7712
              If you go check at Ace Hardware, you should be able to get S.S. screws to replace them with. No rust, no sticking, and looks good.
              • snowdog51
                • 348
                • st. paul ,mn
                alan
                i put a 96 zx900 master on xs1100g with
                steel lines ,not it will do abrakee
                as ever bill
                bill hane
                • MacMcMacmac
                  • Dec 2006
                  • 127
                  • Ottawa, Canada
                  PartsNMore m/c worked beautifully on my XJ turbo with braided lines. It's almost as heavy as an XS.
                  • SG-Olli
                    • Apr 2005
                    • 118
                    • Solingen, Germany
                    On mine I got a 14 mm Suzuki master cylinder. That's roughly 9/16 inch.
                    With SS lines it and proper bleeding it makes the brake feel almost like on a modern bike.
                    XS1100 and XS650- what do you need more?
                    • thewiz
                      • Oct 2006
                      • 1115
                      • Wilksboro, NC
                      Looks great !!
                      Nice mod. Don't forget the goose neck pinch bolt either .... looks like a Mikes handle bar clamp ..... which bars are they? I hate the buckhorns on my SF.
                      80G Mini-bagger
                      Past XS11s
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        Ah yes the buckhorns many people like them for the comfort factor. But, they are one of the things that make the bike look old and slow. JMHO
                        Mine are the superbike bars. They can be had from bikebandit for $15.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • 79XS11F
                          • 3563
                          • Ottawa, Ont. Canada
                          Looks great. very symmetrical, neat and tidy :-)
                          Rob
                          KEEP THE RUBBER SIDE DOWN
                          1978 XS1100E Modified
                          1978 XS500E
                          1979 XS1100F Restored
                          1981 Suzuki GS1100
                          1983 Suzuki GS750S Katana
                          1983 Honda CB900 Custom
                          • petejw
                            • 2269
                            • sydney australia
                            Nice work, once again
                            and congrats on ur promotion. :-)
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            1981 xs1100 RH (aus) (5N5)
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                            • Mathh
                              • Nov 2006
                              • 673
                              • Beek, Netherlands
                              well done 81xs! Very clean looking. Like the new electrical switch and throttle on the right too! Where are they from?
                              MV Agusta Brutale 910R '06.
                              Yamaha MT-09 Tracer '15 grey.
