I really screwed the pooch!
  • dougger
    • Oct 2007
    • 18
    • Rochester, NY
    Help!! I let the battery on my 80 xs11 get too low and tried to jump it with cables from my wife's car. I'm okay so far, but I cross connected the pos and neg and shorted something. I have checked all of the fuses behind the right side cover, but could not locate any fuses behind the left side cover per the owners manual. Any thoughts?
    1980 XS Eleven Special
    Black on Black
  • mro
    • 4276
    • Hayward, California
    main fuse
    Left side near top, small rubber box about 1 1/2 inch square...
    mro
    BTW, only pos side of jumper has to go to battery, neg can go to engine or bare spot on frame
      • 7765
      If there is the fuse on the left side, it may be closer to under the seat. Look for an inline glass fuse holder that has room for a spare fuse.
      Good Luck!
      • dougger
        • Oct 2007
        • 18
        • Rochester, NY
        Hmmm.... I checked, but no fuses. Let me make sure that I'm looking in the right place. On the left side of the bike I am looking at the tool kit and the neg side of the battery. I don't see anything resembling a fuse block. There have been a couple of mods to this bike, like an oil cooler and different signals. If someone was going to move or eliminate this fuse cluster, where would it go?
        Black on Black
        • dougger
          • Oct 2007
          • 18
          • Rochester, NY
          Well...I just pulled the battery...no electrolyte solution at all...is that bad? Holy crap. Does anyone have a recipe for home made solution?
          Black on Black
          • Crazcnuk
            • 2980
            • Hinton, AB, Canada
            Just fill it with water (distilled?) and charge it.
            When a battery is dead, it's just water in there, albiet very bad tasting water!
            (don't ask me how I know...)
            '05 ST1300
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              Replace the battery ... Yes you can fill it and charge it but your asking to have it let you down somewhere when unexpected. These bikes need a GOOD battery to run the electrical system so taking a battery and using it after it has been let to dry out or even worse had the fluid boiled off by over charging is playing with fire .
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • Crazcnuk
                • 2980
                Well, unlike the suspicious sams around here, I never assume anything.
                I would fill it and charge it. Slowly, overnight at 2amps or less, then TRY it.
                It is likely hooped, but it never hurts to try it. You'll know one way or the other pretty quickly.
                You can also have the battery tested, if it takes a charge at all.
                As for letting you down, ANY battery, or any other component can leave you stranded at any time. Just replacing things because it might let you down means you can't keep any vehicle for more than the warranty period!
                '05 ST1300
                • 79XS11F
                  • 3563
                  Yes any part can let you down at any time but running with parts that are known to be questionable is asking for trouble. Any mechanic can tell you that PREVENTATIVE maintenance is always cheaper then waiting until it breaks.
                  PREVENTATIVE maintenance is good practice. Replacing a battery that has been let to go dry is PREVENTATIVE maintenance and in my opinion good advise. It's like replacing tires when the wear bars tell you to do so instead of waiting until loose control of the bike in a corner.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • GNEPIG
                    • Apr 2005
                    • 1657
                    • fl
                    PREVENTATIVE maintenance is good practice. Replacing a battery that has been let to go dry is PREVENTATIVE maintenance and in my opinion good advise. It's like replacing tires when the wear bars tell you to do so instead of waiting until lose control of the bike in a corner.
                    Rob
                    Wow!
                    Spoken like a professional Rob.
                    In other words: don't be a cheap b@stard and it won't let you down.
                    • Crazcnuk
                      • 2980
                      No, it's like replacing parts because you don't like the date they were made!
                      The tire bar analogy doesn't fit, because those bars are telling you your tires are wore out. What I am talking about is replacing stuff when you have no indication there is anything wrong with them.
                      I prefer to test them first, rather than assume. In this case, the battery will likely not even take a charge, then he will know he needs a new one.
                      If I filled it, charged it and it worked, held a charge, etc. I would use it until it wore out, just like any other battery.
                      I do preventative maintenance on critical parts like wheel bearings, brake pads (if I don't know the history), All fluids, and anything else that could kill me unexpectedly.
                      "Not one of those that keep the landfills full, and parts dealers smiling"
                      '05 ST1300
                      • mro
                        • 4276
                        Does not look like a fuse block. Has but two wires, one in and one out. (think either red or red w/white stripe)
                        Located before battery, just under top of frame left side behind side cover. (Unless aready used should be a spare fuse in rubber block.
                        mro
                        BTW,
                        nothing works when main fuse blown.
                        No lights and won't crank.
                        • Hobbit
                          • Nov 2002
                          • 372
                          • Jacksonville, FL
                          Battery
                          The problem with a battery that has been dry is that the sulfer on the plates seperates from the plates and drops to the bottom of the battery. Not only are the plates missing some of the chemicals they need to react, the sulfer can short across the plates at the bottom causing the battery to fail.
                          A sulfated battery will normally take a charge but has no residual charge. To test for this, hook up a voltmeter and turn on the ignition(don't start the engine). If the voltage drops quickly with just this minimal amperage charge, the battery is sulfated.
                          Walt
                          80 XS11s - "Landshark"
                          79 XS11s
                          03 Valkyrie
                          80 XS Midnight Special - Freebee 1
                          78 Honda CB125C - Freebee 2
                          81 Suzuki 850L - Freebee 3
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            Fuse holder
                            The fuse holder on my bike is easily accessed by removing the seat and lokking down on the left side just rear of the battery . It is in a rubber block mounted on the frame crossbar by a metal tang similiar to the one that holds the flasher.
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            Iridium plugs w/ 1k caps
                            MikesXS front master
                            Loud Horns (Stebel/Fiamm)
                            Progressive fork springs
                            CIBIE headlight reflector
                            YICS Eliminator
                            • 79XS11F
                              • 3563
                              If you don't think the battery is a "key" component your mistaken. It is the HEART of what is already known to be a weak electoral and charging system. No having a battery fail will not likely kill you but could leave you stranded somewhere at the most inconvenient place or time (Murphy's law will dictate that's that will likely happen) and in a worst case could lead to the damaging of other key components in the electoral system. Buy a battery when you know your is most likely fried ... or wait until stranded and pay for a tow and or taxi, buy a new battery and be inconvenienced. It's not like replacing light bulbs before they blow? and no it's not like replacing parts because one does not like the date they were made. If I felt like that I would not own a 29 year old bike .. would I now?
                              Rob
                              1978 XS500E
                              1981 Suzuki GS1100
