Hi Bluegiant,
Set your idle mixture to suit normal running temperature, and deal with the starting issue seperately.
The choke should be making such a big difference to the mixture that a tweak on the pilots will make no difference at all to a cold start, but will make it run infinitely worse for all the time it is NOT cold-starting..........
The pilot adjustment is the main factor in the whole medium throttle/ lower revs range, which (if we are honest!) is where most of us drive most of the time. It is the range which decides whether a bike is "Fun" to drive, or "A pain in the @ss, tempramental s*n of a B!tch!"......... So set the pilots properly!....... "1 1/2 turns out" is only a starting point; there are good guides on here, or find someone who "has the Ear!"..... they do exist.
Sorry; rant over.......
AlanB
AlanB
