Hi guys!
This is Sibgyp's other half, mentioned in the 'We are so lucky' thread. Sib and I are just going to use the same account to make things easier.
We got the bike running after solving the electrical issue (other electrical tests still need to be done to make sure every thing electrical is in proper working order, as we were told by the obvious hack who 'worked' on it that the alternator is not putting out the required voltage to charge the battery that doesn't seem to be draining), but now, when we start the bike, it's running like it has a load on the engine. When we kill the ignition, we can hear the starter clutch freewheeling to a stop, as it does when you go to start a bike (or car, for that matter) but it doesn't quite fire, and the compression that's built up spins the engine and hence the starter (most notable on older Chrysler products... I'm sure many of you know what I mean... lol).
Since I do not hear this on my bike (or any other vehicle), and the bike's running like it has a load on it (as well, it won't idle at all with the choke off, even after plenty of warm up time in relatively warm weather), I'm assuming the starter clutch remains engaged after the bike fires.
That's where we are at this point. Any ideas?
Lots and lots of thanks in advance!
