Vetter trunk 'bunkee'
  • Filter
  • Vetter trunk 'bunkee'
    I need one of the rubber mounts for the vetter trunk. I have one broken one.
    I may have to buy a set of Vetter's website, but thought I would see if anyone had one or two from a broken set.
    Also, I read somewhere that Platinum plugs are not recommended for these bikes? Just wondering why.
    '05 ST1300
  • #2
    G'day Craz
    I've got three out of a set of four if no one else chimes in. They are used and pretty old but still quite functional, I bought a new set from the Vetter site, might be just as well to do the same?
    Never heard of platinum plugs but I suspect anything other than the Vetter bunkees might interfere with the overall harmonics and you'll end up with a whistling top box or worse, annoying vibrations.
    Dan.
    Automotive Imbecile.
    Proud owner of 'The Swiftcicle'. (Swifty for short)
    '78E Full Vetter Dresser.
    1196 Big Bore Kit.
    • #3
      lol, Platinum spark plugs.....
      I found the little rubber nuts, used to connect the lowers to the fairing were available at Canadian Tire, here, for $1.25ea. I thought maybe there might be an available source for the rubber trunk mounts as well.
      I would give your 3 a shot, if you don't need them. If one breaks, I would get two more strikes at it. Not sure what postage would cost from down under.
      Right now, with one broken, the trunk shakes more than it should and I assume it will hasten the demise of the other 3.
      '05 ST1300
      • #4
        Platinum plugs
        Well I have Iridium plugs holding my trunk in place and it's quiet as a mouse.
        Like I said, if no one else chimes in, the three are yours.
        And my Iridium plugs work great, easier starting and better fuel economy (not measured scientifically, but my fortnightly fill was three litres less than usual)
        Can't comment on the power since they were installed at the same time I did the rebuild.
        And they're cheaper than the platinum.
        Dan
        1196 Big Bore Kit.
        • #5
          I only picked up the platinums because they were the only ones Canadian Tire carried that had the removable tips. But I read, somewhere here, that platinum plugs were not recommended for the XS's. Of course I saw that after I bought them.
          '05 ST1300
          • #6
            Seems platinum is OK
            Originally posted by Snow
            These are in alpha order by mfgr.
            XS11 Spark Plugs
            AC Delco:
            R42XLS
            Rapid Fire #AC-4
            Autolite:
            #ASP-63
            Platinum #ASP-AP63
            Double Platinum #ASP-APP63
            Bosch:
            Bosch #BSA-7500
            Bosch Platinum #BSA-4216
            Bosch Copper Electrode #W7DC
            Bosch Platinum Electrode #W7DP
            Bosch Super 4 #WR78
            Champion:
            stock# 3415 - Mercedes plat
            Champion Standard #N9YC
            Champion Internal Resistor #RN9YC
            Platinum #CHA-3415
            Copper Plus #CHA-415
            Champion Wide gap 0.032" (0.8mm) #N9YCC
            Champion V tip electrode, Gold Palladium Tip #2415
            UN79Y=ngkBP6ES
            RN10Y=ngkBPR6ES
            RN10Y4=ngkBPR6ES-11
            NGK:
            BP6ES
            #6764
            #7333
            BPR6ES #7131
            V tip BP6EY
            Platinum BPR6EVX
            BPR6ES-10 widegap
            BPR6ES-11 widegap
            BP5ES #7832
            Splitfire:
            #SF6C
            Triple Plat #TP6C
            Information obtained from me asking at parts stores and also from
            http://carport.virtualave.net/mgb_ov...nter_parts.htm and fusionking.
            Feel free to spread this info as you see fit.
            I cleaned up my sparkplug list and decided to repost as a new thread so future spark plug # searchers can find it easily.
            1196 Big Bore Kit.
            • #7
              Re: Vetter trunk 'bunkee'
              Originally posted by Crazcnuk
              I
              If you go to Boschs website and do a search for "wasted spark", it will give you the lowdown on the platinum issue. I had problem when I put new Platniums in my Olds 88 with the 3800 v6. After about 200 miles I got a real bad miss, did some research and found that these plugs do not work well at all in the 3800. It also answered the problem of the miss in my 2.2 Cavalier. There is some very in depth information about this on the bonneville.com website. I switched plugs out in both cars and the miss went away. Go figure.
              • #8
                So it's just an issue that they may or may not work well in certain applications?
                So far they seem to be fine in the bike, but I thought maybe they just won't last as long as other plugs.
                I have a spare set of BPR6ES for when I need them.
                '05 ST1300
                • #9
                  If you still have those bunkies, I sent you a PM, Stralya.
                  '05 ST1300
