1982 XJ1100. What is that sound that I hear coming from under the seat when I turn the ignition key on? I only notice it when I start the bike cold. In a car, I would think it was an electrically activated fuel pump. Is it just some sort of ignition relay?
Mysterious noise
Tags: None
On my XS (the noise actually came from under the gas tank) it ws the headlight relay buzzing. I replaced it.
The headlight relay would buzz (on/off/on/off/on/off rapidly) at anything below 2000rpm. I assume it was just dieing. When I first got the bike going it didn't work at all.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/trade -
The headlight relay would buzz (on/off/on/off/on/off rapidly) at anything below 2000rpm. I assume it was just dieing. When I first got the bike going it didn't work at all.The life of a Repo Man is always intense.Comment
Ditto, to olebiker's reply. I have an XJ1100j and no noise.
I would think it is an indication of failing. You should get a replacement to have available when needed.Gary Luckin
'78 XS1100E Full Dress
'74 DT175A Enduro
'86 Husqvarna 400XC Cross Country
My Avatar is "Rolle Free"
breaking the speed record in 1948
check this out;
http://outside.away.com/outside/destinations/200701/utah-bonneville-salt-flats-motorcycle_1.htmlComment
I would think it is an indication of failing. You should get a replacement to have available when needed.The life of a Repo Man is always intense.Comment
Hey Bruce,
TAKE THE SEAT OFF, and then turn it on and listen to see where it's coming from, could be TCI, could be several other relays that are under there around the frame near the battery! The sliding sound may just be a relay energizing, and then the click is it actually throwing into contact!
T.C.T. C. Gresham
