Tech/Mech Wanted for Hire
    • 6763
    I am in NJ and my bike problably needs the 1st/2nd gear Dremel fix in the tranny.I have no experience in this regard so I am willing to pay someone who has.If you live in the PA/NJ/NY area and have done this fix ...I could really use your help.I will pay for all necessary tools and materials needed as well.I would be willing to watch and learn and to help as well.I don't mind getting my hands dirty but would need the guideance of someone who knows what to do. PM me.... Ben Miller
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    I had no XSperience doing the dremmel fix until I did it. It's really not as difficult as it seems reading it. It can be frustrating, but not rocket science.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • 79XS11F
      • Jul 2006
      • 3563
      • Ottawa, Ont. Canada
      Hey Ben .. I was sure I read in another post that cash was not an issue .. so why not just drop in new gears? from what I understand the new ones will be undercut from the factory> Still have to pull the engine and split the cases but if your just dropping in new gears you'll be putting it back together a lot faster and straight re & re work is a lot easier to perform.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • luckygpass
        • Aug 2007
        • 37
        • Grants Pass, Oregon
        I'm with Pat Kelly,
        I had no experience doing motorcycle engine work and followed the excellent advice available here, using both articles written on the fix and have 100% success.
        I did it without flipping the bike. You just have to do 2 functions with the left hand and 3 functions with the right hand when reinstalling the shift forks/counterbalance shaft/gears in place simultaneously to mesh evrything at the right time and sequence to get the shaft back in the motor. It is a little tricky and you will have a couple of shift forks bean you in the forehead before you get it right. You'll know what I mean when you are there.
        You could pull your bottom cover and look at the gears. If they are not thrashed doing the fix would be a whole lot easier than pulling the engine and splitting the cases. If you do that you might as well strip the rest of the bike, powdercoat the frame, and do a ground up restoration.
        Gary Luckin
        '78 XS1100E Full Dress
        '74 DT175A Enduro
        '86 Husqvarna 400XC Cross Country
        My Avatar is "Rolle Free"
        breaking the speed record in 1948
        check this out;
        http://outside.away.com/outside/destinations/200701/utah-bonneville-salt-flats-motorcycle_1.html
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Split cases?????
          No need to split the cases. Secondary shaft comes out and back in pretty easy. I also did the tranny fix 3 times now and was easy the first time even. Just print the instructions here (many pages) and don't let the shift forks drop in the engine if you turn it upside down.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • olebiker
            • Aug 2007
            • 692
            • Kingston ON
            Re: Split cases?????
            You gotta admit this sounds funny (three times)
            http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
            • GtrMn
              • May 2003
              • 248
              • Springfield Va
              Getting cranked up to do mine. Still need to figured out what's happening with 5th gear and how it engages. No problem with 1st or 2nd gears.
              XS 1100 LG
                • 6763
                check out the thread on" high rpms to launch" on the 2nd page the 11th post down by TC there is a link to tech-tips on how to do the 1st/2nd gear dremmel fix..this might be of help to you too.
                • planedick
                  • Mar 2005
                  • 2068
                  5th gear issues
                  Usually the problem with 5th gear is outside on the left side having to do with the lining up of the parts on the shift drum shaft.
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  • GtrMn
                    • May 2003
                    • 248
                    • Springfield Va
                    Huh? Run that by me again?
                    XS 1100 LG
                      • 7818
                      The 5th gear problem COULD be just an adjustment. This is under the left side cover(need to remove the shifter). You should be able to check it in less than a hour, including the oil change you were going to do anyway. The Diagram and photo's are in the "Tech Tip" section, at the HOME page.
                      • GtrMn
                        • May 2003
                        • 248
                        • Springfield Va
                        Aaah...Already did that ..Thanks!
                        XS 1100 LG
                        • 79XS11F
                          • Jul 2006
                          • 3563
                          Originally posted by luckygpass
                          I'm with Pat Kelly,
                          Re & Re the engine is a lot easier to do then " strip the rest of the bike, powdercoat the frame, and do a ground up restoration." just because the engine happens to be removed. Trust me .. the two jobs are no comparable.
                          In any case If I am mistaken about the need to split the cases to do a proper trany inspection and repair then MY BAD. i was under the impression that only the simple fixes could be done with the engine in the frame. Do these gear dog issues only affect gears that sit on the secondary shaft?
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • planedick
                            • Mar 2005
                            • 2068
                            Yes
                            The tranny repairs for 1st and 2nd gear fix is on the secondary shaft and it's not necessary to split the cases.
                            Drilled airbox
                            Tkat fork brace
                            Hardly mufflers
                            late model carbs
                            Newer style fuses
                            Oil pressure guage
