Bike is running good and I noticed the oil light never comes one. I pulled the cover and found the reason. No bulb. Guess PO or one of his numerous mechanics had fixed an oil light problem by removing the cause, the bulb. I replaced the bulb and sure enough it lights up and stays lit.
I pulled the wire off the sensor and the light turned off. I then pulled the sensor. Looked clean. Attached the wire back to the sensor, grounded the sensor and blew air into sensor using vaccuum gauge. Light went out. Figured this means sensor and wiring okay. Checked oil level, ti was at top line in window. Fired up beast and watched oil level drop. Guess I got pressure or at least the pump is working.
What should I do next? Is their an easy way of checking the oil delivery to the heads?
Scratching my head again.
Ernie
Ernie
