Hi List,
The forks are a touch soggy with the sidecar attached. Progressive's springs claim to be stiffer than stock but will cost me ~$80 that I ain't got. OTOH, air is free.
Clymer's recommended setting for the pump up forks at "maximum bike load" is 21psi. With the sidecar alone it's gotta be about that and adding my body mass on top of that undoubtedly puts it over.
What Clymer's won't tell me is how hard can I pump the forks before they blow out when I hit a pothole in the cratered ruins that Saskatoon has for streets?
Suggestions anyone?
Suggestions anyone?
but hey its does handle better with a bit more air.
It takes very little volume and if you use a compressor, your can crater the seals real quick with over inflation. I will set my discharge pressure way down (15-20lbs) and just give a real quick shot of air to each leg. Then, with an accurate, low pressure tire gauge, I will drop the pressure down to what I want. You will easily drop a pound just checking the pressure so it can be pain to get em equal. I usually run 'bout 12-15 psi when running 2 up and full travel gear on my full dresser. BTW, I am running 15w oil here in balmy central Texas.
I max the tire pressure out (44psi, Elite II's) when runnin fully loaded. (The bike, not me
