I've got a XJ1100. From time to time it will coke up on me as though it's not wanting to fire. There seems to be no pattern to it. It has done it right after startup and going down the road. After I've stopped (at a light) it seems to not want to accelerate. It sounds like it's not firing on all cylinders. After I rev the engine it'll be ok. It's becoming harder and harder to start in the mornings as well. It'll backfire and from time to time I even get some black smoke. I took my spark plugs out and as I figured they were black.
Now before I had this problem I had another one. The bike had a strange idle. It would bounce up and down from 1100 to 1500 rpm. I had to keep the choke on to keep it running. This seemed to fix itself. But after this stopped it start into what I mentioned first. Do you think the problems are related?
Where do you guys think I should start to tackle this from? I'm thinking turning the carbs set screws down as the plugs are black. How far should I turn them... and where are they located on the carbs. I've never worked on carbs before so this is a first for me.
Any and all help will be appreciated. Thanks, from a fellow rider.
But otherwise your advice is also good!
