When adjusting the float level on the carbs....do you need to REMOVE the float bowl gasket or do you set the levels with the gasket still in place? Im afraid I will tear all my gaskets to hell if I try to take them off.
Quick Float Level question..
80XS11G (heavily modified) "Snot Rokkit"
Deuces Wild
Custom Paint & Body
1200 N. Wall Sreet
Calhoun, GA 30701
770-608-3779Tags: None -
Yes set with gaskets removed as per the factory manual
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
Hi Guys,
If you don't think the gaskets will survive, then just subtract the thickness of the gasket from the setting, and measure on top!
Theoretically not as accurate, but better than putting the carbs out of use totally!
However, I have always managed to get the gaskets off without damage..... Just take it sllooooooowwlyyyy!
AlanBIf it ain't broke, modify it!Comment
These are the original gaskets so they are pretty "stuck". I'll try taking them off first....and if not...I'll just remove the thickness of the gasket from my specs. Thanks.80XS11G (heavily modified) "Snot Rokkit"
Deuces Wild
Custom Paint & Body
1200 N. Wall Sreet
Calhoun, GA 30701
770-608-3779Comment
