Stupid Question
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Stupid Question
    got new coils from MikesXS, don't need the ballast resistor.....
    will just unplugging it do the trick or do I need to do something else??????????????
    My Photo Bucket
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    I am certainly no electrical wizard bit I do think you will have to close the circuit when you remove the resistor.
    Mike Giroir
    79 XS-1100 Special
    • randy
      • Dec 2003
      • 4521
      Mike is correct. When you remove the resistor, just plug the two red/white leads together. Otherwise, no sparky.
      P.S. Are you sure you don't need the ballast resistor? Excuse me for asking, but I've lost track of these coil swap threads! Too damn many of them!
      • renegade_xs11g
        • 462
        • Mid-Michigan
        THANKS,
        randy.....according to THIS, the coils don't need the resistor
        My Photo Bucket
        • randy
          • Dec 2003
          • 4521
          According to that, it's confusing. Talks about different years, but the basic fact is all of our bikes need 3-ohms on the coil primaries. The early 78-79 do it with a 1.5-Ohm coil and a 1.5 Ohm resistor.
          The later 80 and up do it with 3-Ohm coils, no resistor.
          So if the Mike'sXS coils are 3 Ohm, GREAT!
          If they're 1.5 Ohm, keep your resistor or you'll burn out your TCI.
          • Stralya
            • Apr 2006
            • 791
            • 'Blotto Grotto' Wodonga, Victoria, Australia.
            Thanks Randy
            I'll plug mine back in.
            Automotive Imbecile.
            Proud owner of 'The Swiftcicle'. (Swifty for short)
            '78E Full Vetter Dresser.
            1196 Big Bore Kit.
            • pggg
              • 1609
              • NZ
              Here's the instruction sheet I got with my 1.5 ohm dynacoils, they've been running good for years with no ballast resistor and no spark cap resistors
              • Stralya
                • Apr 2006
                • 791
                OK
                Unplugging!
                1196 Big Bore Kit.
                  • 5062
                  ?? I thought the 81's did away with the ballast resistor but all earlier bikes needed them.?
                  • Stralya
                    • Apr 2006
                    • 791
                    Ummmm
                    Maybe I'll just install a toggle switch and go from plugged to unplugged as the whim takes me?
                    1196 Big Bore Kit.
