Crossing over...
  • jwoell
    • 63
    • Wichita, KS
    Redefinition
    OK bros, I'm looking at something totally new here at this point. I drove it home today and what my coworker said was completely true. The bike has a brief power loss right before the "shotgun goes off". I can't really explain it, the bike loses power for about half a second and then all of a sudden...BOOOM...out the exhaust. So I had thought it was maybe something simple like float level or pilot jets, but now I'm considering the pick up coil or anything else.
    To define it in more detail, I'd be cruising along at about 3-4K RPM and upon any sort of deceleration (possibly just out of the blue) the bike would lose all power for about a half second (even if I tried to goose it a little) and then it would backfire (shotgun style).
    So my thoughts are that I rebuilt the pickup wires for sure (never been done), replace the park plugs since they're a little old, I'm considering doing the coil upgrade, I dunno, just asking for opinions.
    Thanks
    '81 XS11 SH (XSelsior)
      Sounds like the dreaded pick up coil wires. Do a search and you'll find many a discussion about repairing them.
        • 5047
        Re: Redefinition
        The poppity pop on deceleration can be an indication or leanness. However that big bang is unburned fuel from one or more carbs being overly rich or non atomized fuel (like a pilot jet fell out or fuel going around the float valve or intermittant spark.)
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          a agree .. this sounds electoral and the BOOM is all the unburned gas in the pipes when she re-fires
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • jwoell
            • 63
            • Wichita, KS
            OK, looks like I have a project for the Labor Day weekend. I get the sense that it's an electrical issue, so i'll check the pickup coil wires and mease the resistance on the coils, maybe drop in some new spark plugs, etc. I might have a run through the carbs too if it's possible that a pilot jet fell out or something, but it runs quite well other then the backfiring. Anyway, thanks for the suggestions.
            • 81xsproject
              • 3185
              • Fortuna, CA
              I promised a pic of the new home-jobby synchronizer I mentioned at the beginning of the thread. Here you go.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • mro
                • 4276
                • Hayward, California
                Here you go.
                B'out time
                I don't know Jessie...
                Think I'd a used a green liquid
                mro
                btw, notice your using the same kinda shelving (cinder block)
                that I used in my first apartment
                • 81xsproject
                  • 3185
                  • Fortuna, CA
                  ha ha mro, I used the only colorful thing I had (MMO) that would mix with oil. Besides, maybe my carb synchronizer is secure enough in itself that it isn't ashamed to display pressure differences in PINK
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                  • oldbiker648
                    • Jul 2003
                    • 182
                    • Richmond, VA
                    A couple of drops of food coloring in the water would work as well.
                    _________________
                    John
                    78E
                    79 SF (2)
                    80 G "The Beast"
                    81 H "The Dresser"
                    79 XS650 II
                    82 650 Maxim
                    70 DT-1 Enduro
                    66 Honda CL-77 Scrambler
                    96 H-D Road King
                    "The road to hell is paved with good intentions."
                      Hi Oldbiker,
                      green or yellow dish soap'd work too. It's viscosity is away more than water and that's another advantage when used as a manometer fluid. However, water or any water+dye mix has the same problem, if by some mischance it gets sucked into the carbs and into the engine it turns into a major bother. Oil-based fluids, the manly red of ATF or the delicate pink of MMO, merely mix with the gas in the carbs to make the engine run smoky for a while.
                      • oldbiker648
                        • Jul 2003
                        • 182
                        • Richmond, VA
                        Fred,
                        Yep, a little oil in the carbs beats ANY water in them. Have you ever heard of anyone actually having had the misfortune to suck mercury into their engine as a result of a rapid increase in vacuum? I've read about that being a possibility if you used a mercury manometer. I can only imagine what that would do.
                        John
                        _________________
                        John
                        78E
                        79 SF (2)
                        80 G "The Beast"
                        81 H "The Dresser"
                        79 XS650 II
                        82 650 Maxim
                        70 DT-1 Enduro
                        96 H-D Road King
                          That would be quite nasty, but if you use in-line restrictors like the ones that came with the set I bought, it won't happen. The tiny orifice in the restrictors also helps to dampen out the vacuum pulses so you get a more consistent sync.
