back fireing bike after washing it
  • brownbear1000
    • May 2007
    • 83
    • Bay View wisconsin
    bick is still back firering after 4 days took it to work ran ok but after 3 mile it started back fireing a gen had to ride it home with the chock on when i got home it ran ok what is going on?
    this all started after I power washed it its an xs1100 is it something in the carbs?
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Pickup Coil Wiring Repair ?
    Not an expert but would suggest searching the threads on repairing the Pickup Coil wiring . Maybe the pressure washer helped a wire to break down by the timing plate (cover near your left toe)
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • dragxs11
      • Jun 2003
      • 519
      • Reno, NV
      Thinking off the top here, but water in the gas? Maybe some h20 found it's way through the gas cap.
      1980sg-Stocker-- Sold
      1980sg- Cruise Missile- Sold to RODS454
      1990 ATK 604- Ditch Digger
      2005 BMW K1200S- Killer Bee
      2005 Suzuki GSX-R 1000- trackbike
      • GtrMn
        • May 2003
        • 248
        • Springfield Va
        Check and see if you have water in your spark plug boots..my 2 cents
        XS 1100 LG
        • COOL TOM
          • Jul 2005
          • 288
          • CANTON, IL
          WASHING
          DO NOT WASH MOTORCYCLE WITH POWER WASHER OR CAR WASH!!!!
          Wash them at home with garden hose and bucket and keep the water OUT from under the tank. Be careful behind the right side cover too. Also let the motorcycle dry off a little while before you start it up again, go drink a soda or a cup of coffee while you wait.
          Thanks Tom
          82 XJ DAILY RIDE
          78 XS1100E FIXING UP
          79 XS1100F PARTS BIKE
          79 XS1100SF NAKED BIKE
          80 XS1100SG FULL DRESS BIKE
          82 XJ IN THE ROUGH
          • xsilerating
            • Dec 2006
            • 430
            • Eastern Ontario, Canada
            I've had the same problem but to a greater extent. Though I'm generally a fair weather rider, I've been caught in the rain on a few occasions (not heavy downpours) and each time the bike ran like it was firing on one cylinder only. It also happened following a restrained bucketwash/garden hose as well. I'll try the above suggestions and, perhaps, my comments here may provoke further response.
            re: dragxs11 - on each occasion, the bi ke returned to normal function after a short drying out period of either letting it sit or keeping it running, so I doubt that it would be water in the gas. (Never-the-less, a good comment should the problem not rectify itself in short order.)
            Ron
            1980 XS11 LG (Diablo)
            1980 XS11 G (Bagger)
            1978 XS11 G (White Knight)
            1978 XS11 G (Skeleton)
            2016 SS (S.S. Flyer)
              • 7735
              I would start with pulling the spark plug caps off the wires, They just unscrew. Then cut about 1/4" off the end of the wire, and install the caps with Dielectric Grease around the boots between the cap and the wires. I would measure the resistance in the cap before installing, to verify it's no more than ~5K Ohms. If the resistance is ~7K Ohms or higher, replace the caps. You can buy them at almost any auto parts store that carries NGK products.
              Next in line, use the dielectric grease to seal ALL the connections on the bike. Last place to check is the pickup coil wires. Check in the "Tech Tips" section from the MAIN forum page for that procedure.
              Remember, if you have ONE cap that is shorted to ground, that coil WILL NOT fire a spark plug.
              • brownbear1000
                • May 2007
                • 83
                back fireing bike
                when I got home with the bike it ran ok but when I took it out again after about 3 miles it started back fireing again and I had to put the choke on full to stop the back fireing. It sounds like a gun going off .bang bang bang etc. and when I get back home and take the choke off and restart the bike it runs ok. It does it intermittently. And it has no power at all
                • Jerry
                  XS & TRUE XJ GURU
                  • 3023
                  • Elma, IA.
                  Several years ago I was riding with one of our members, he had the same problem. Turned out water had gotten on the coils and was causing an arc between one of the posts and the frame. Intermittent problem. We rode for many miles, then suddenly the coil dried off enough to quit arcing and away we went. Took quite a while and many miles to work properly...I would look at your coils to see if you can see any moisture or evidence of arcing.
                  Jerry Fields
                  '82 XJ 'Sojourn'
                  '06 Concours
                  My Galleries Page.
                  My Blog Page.
                  • renegade_xs11g
                    • 462
                    • Mid-Michigan
                    Before you do anything else.....
                    drain your gas, from tank AND carbs if you can.
                    refill tank with new gas....add DRYGAS too!!! just in case....
                    you may have gotten water into the tank.....
                    go for a short ride...maybe up and down YOUR street a few times
                    IF it gets better soon your in business
                    but..... I think, you may have an ignition problem
                    4 DAYS later and still acting up???????
                    Good luck, and keep us posted
                    My Photo Bucket
                    • xssiveone
                      • 766
                      • Windsor,Ontario,Canada
                      Re: Pickup Coil Wiring Repair ?
                      I go with this one... a buddy had the same problem and it drove him nuts. Finallly swapped his pu coils with my good spare and no more problems.
                      Brian
                      remembering the same thing!
                      • GtrMn
                        • May 2003
                        • 248
                        • Springfield Va
                        Could be water inside the Timing cover....would take quite a while for it to evaporate. Could effect the pickup coils too.
                        XS 1100 LG
                        • desert1
                          • 750
                          • Grand Desert, Nova Scotia, Can.
                          resistor
                          Had that very problem a few years back just as you describe, in my case my plug caps had resistors in them, they were in poor coroded condition, and water got to them shorted them out so that the plug would fire intermitently......something else for you to check Bear....
                          Bruce
                          Bruce Doucette
                          Phone #1 902 827 3217
                          • brownbear1000
                            • May 2007
                            • 83
                            back firing bike
                            after I road My bike home with the choke on to keep it from back firing the right sidemuffler had turned blue from the brake lever back to the end and started to burn My sadol bag . the left side is ok . why did the right side get so hot? Choud it be unburend gas from a misfiring cylinder on that side no. 3 or 4.
