rusted xj banjo bolts
  • Filter
  • rusted xj banjo bolts
    hey the bike has sat for about 10 years and the banjo bolts to the brake system are prett cruddy and rusted. should i try to get them cleaned or replace them?
    79 xs11 standard
    8mm msd wires
    tkat fork brace...
    Fox shocks...
    mikes650 front fender
    led's gallore...
    renthal bars
    gold valve emulators
    vmax tensioner
    Rifle fairing
  • #2
    Banjo Bolts
    I tried to replace mine locally, but no luck because of the thread pitch. You could order them from mikesXS though.
    • #3
      Some of mine were in rough shape as well but the bolt does not make the seal .. the copper washers do so put the bolts to the wire wheel and clean them up as necessary. How good or bad they look will of course depend on just how much rust there is. I don't even replace the copper washers. I just heat them up good and doing that fattens them back up so they can be reused. Just don't melt them when your heating them up.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • #4
        Yeah, just clean them, if you find you have some that are to far gone send me a PM I have several used ones off of brakes for the xs1100, just indicate if for caliper,brake master or front brake spliter some are longer. andreas
        • #5
          thanks! i just hope there is not too much rust that it gets into the brake system when i reconnect everything.
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          led's gallore...
          renthal bars
          vmax tensioner
          Rifle fairing
