Hey there was having a wonderful day working on the XJ until I STRIPPED THE FREAKING THREADS ON TOP HOLE ON LEFT FRONT CALIPER!!! Crap! before this happened I actually solved one problem. Squeaky breaks front and rear. cleaned and used proper brake lubricant on correct caliper points / slides and then aligned up the front end nicely. anyway during the process of putting the left front caliper on I stripped out the top hole. I did check other threads didnt really find everything I was looking for so here are my questions.
First off proper torque specs for caliper mounting bolts? didnt find this in owners manual but saw general torque specs for 14mm bolt at 61 foot pounds is this correct.
My caliper bolts have a lock washer then flat washer on them first before going into mounting holes on lower fork legs is this correct? This is how they were when i got the bike.
What is the size / thread pitch etc for the stock bolt?
What would be the next size up from this stock bolt with suggestions as to best thread pitch etc?
Thoughts on Heli-Coil vs. re tapping and finding another bolt.
Thanks again
Thanks again
