Carbs were NOT dunked in cleaner when rebuilt, just sprayed. On the '81, the idle mixture screws are NOT adjustable, they're capped off at the factory. But I will try that trick forcing the butterflies closed right now...just might take a second, as the problem seems to only come when the bike warms up.
High RPM issue
I'm getting curious to see this for myself, and I'm up for an evening ride. If you want me to come down, send me a private message with your add. I can try to make it tomorrow around 8.1980sg-Stocker-- Sold
1980sg- Cruise Missile- Sold to RODS454
1990 ATK 604- Ditch Digger
2005 BMW K1200S- Killer Bee
2005 Suzuki GSX-R 1000- trackbikeComment
Update: I couldn't reach all the way in to push on the throttle linkage, but I CAN say that there was resistance and the linkage was going all the way down. In fact, I could rev it up more by giving it some throttle. Oh, and the cylinders with the needles were not moving when it hit the higher RPMs like they were when I first started the bike and gave it a few twists before the problem came back.
Yea, I'm starting to realize how sure it is that there is an air leak, but I still can't find it!1981 XS1100S (former)
2006 Suzuki Katana 600 "BLKMGE"Comment
Capped off does not mean they are not adjustable. It only means you have to remove the caps to get at the adjustments. If the caps have not been removed, there is no way you could have done a proper job of cleaning the low-speed circuits ont he carbs, no matter how much carb cleaner you spray or how much air you blow. Those caps have top come off, the low speed circuits have to be cleaned, then you can get back to doing a sync and setting the pilot screws.Originally posted by BlkMage
Sorry...
Ken TalbotComment
When I said "capped off" I meant kinda permanently. Unless I want to break out a hammer and chissel and chance spliting the carbs wide open.Originally posted by Ken Talbot
Sorry...
I'm not sure on your bike but all of the XS's I've seen with the plastic caps. Well you can put a screw driver under the edge of them and lever the cap off. They can then be adjusted. Your option as to whether you want to put the caps back on.
If and when you go to adjust the idle mixture screws, DO NOT FORCE THEM DOWN TIGHT! The tapered needle that you are screwing down will enlarge the bore it is screwing into and make idle mixture adjustments difficult in the future. Another problem with this is that on a fairly regular basis people jam the needle into this bore then break the tip of the idle mixture screw off blocking off all fuel for idle.
As you turn the screw down, as soon as you meet resistance, STOP. I would run the screws down to the bottom, stop, then back it out 2 complete turns. Start the engine up/warm up then slowly adjust the screw down/up until you reach the highest RPM then go onto the next carb. If the idle gets above 1000RPM adjust the idle speed down before going to the next mixture screw.Comment
_______________________________________________
If you have the sealed plugs covering the idle adjustment screws (like a frost or Welsh plug) Drill a small hole into them, (be shallow with the drill bit, just puncture the surface) Then screw a self tapping screw (sheet metal screw) into that hole, lever the plug out with pliers/vise grips.
Then go ahead with the adjustment as in my previous post.
Oh ya, as Ken Talbot said, if these screws were not removed during the carb clean/they have not been cleaned completely/properly.Comment
Okay Mage,
First....you stated the carbs were synch with the butterflies, but this is just a PRESYNCH, a vacuum synch needs to be done, but not until you find the vacuum leak.
Secondly, those brass caps are removed by taking a small drill bit and drilling about 3/16" to 1/4" down, they are not very thick, and then put a sheet metal screw into it, and then grab the screw with pliers, vice grips, whatever, and wiggle it to knock them loose and remove. Just put some tape around the tip of the drill bit to mark your depth, and go lightly so you won't pop thru too quickly to damage the pilot screws beneath them!
T.C.T. C. Gresham
The good news is that with the later-model carbs on the '81, you don't have to worry so much about jamming a pilot screw in its bore. The later-model screws are the blunt end type which are not so prone to getting stuck and breaking off. This is good.Ken TalbotComment
Thank you dragxs11!
He came down yesterday night for a look, among other things playing with my idle adjust screw, and it worked! I took her out for a run just a few minutes ago, stopped after a while for a final tweak, and it's all set! Thanks again everyone, see you at Tahoe!1981 XS1100S (former)
