dip stick
  • brownbear1000
    • May 2007
    • 83
    • Bay View wisconsin
    dip stick
    looking for a dipstick to ckeck oil in the gear box and shaft drive.
    or at lest a blue print of one so i can make one at work.
    its for a 1979 XS1100
    thank you
    brownbear1000
  • GtrMn
    • May 2003
    • 248
    • Springfield Va
    Check under Maintenance...Oil and lubrication..there's a post there for the dip stick
    XS 1100 LG
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      there's also a guy on eBay who sells them pretty cheap .. search it if you want OEM unit
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • Trikerneil
        • Dec 2005
        • 141
        • Wareham, Dorset, UK
        There is a drawing on the XS11UK site HERE
        Triking - it's a way of life!
        www.trikenest.co.uk
        • LoserShoes
          • Apr 2005
          • 524
          • Bangor Maine
          And you can still get them from Yamaha I believe.
          Steve
          73 Yamaha DT3 - DirtyHairy
          CZ 400 MX'er
          68 Ducati Scrambler
          RC Planes and Helis
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            i took the fill plug out last year to do a gear oil change and now i want to check the rear, however the fill plug won't come loose, is it counter clockwise to remove? i'm bending my allen wrenchs, and i don't even think i torqued it down that hard, help and thanks
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • AlanB
              • Oct 2006
              • 705
              • Scotland
              Hi Mason,
              It is a conventional (right-hand) thread.
              Try warming the housing with a hot-air gun......
              You are stronger than you thought!!
              AlanB
              If it ain't broke, modify it!
                • 7737
                Mason,
                You can also try a STEEL hammer and tap the Allen wrench. The shock will help loosen the bolt. Try putting anti-seize on the bolt threads when you reinstall it. That should keep the steel threads from siezing to the aluminum case.
                • randy
                  • Dec 2003
                  • 4521
                  brownbear1000;
                  PM me and I'll mail you one, i've got some left over from the '07 XSEast rally.
                  • GARTHXS
                    • 1631
                    • Seattle
                    part ##
                    I hear they have the gear oil dipstick available does any one have a part ##
                    91 kwaka kz1000p
                    Stock
                    ( Insert clever quote here )
                      • 7737
                      Yes, here is the Yamaha part number from the online catalog. 2H7-2815A-00-00
                      • Axel
                        • May 2007
                        • 869
                        • Renfrew,Ontario
                        rear filler plug
                        I had to use the breaker bar with the hex key socket to crack it .
                        MAN, it was tight . Even when I tried not to put it back in tight ,next time, I still needed the breaker bar .
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        Iridium plugs w/ 1k caps
                        MikesXS front master
                        Loud Horns (Stebel/Fiamm)
                        Progressive fork springs
                        CIBIE headlight reflector
                        YICS Eliminator
                        • scotto
                          • Dec 2006
                          • 23
                          • Burpengary, Qld, Australia
                          plug screws
                          I just bought new plug screws and gaskets for final drive and mid drive from local dealer. Cost $15 AUS each. Mine were rounded out and time to replace before I couldn't get em off.
                          I recently made a dipstick in 5 minutes, using the template off this site. All I needed was scissors, pen, a ruler and an old plastic sauce bottle - fairly thick rigid plastic. Not flash but does the job and I won't sweat it if I lose the bugger.
                          Cheers
                          Scott J
                          Cairns, Aus
                          Scotty J
                          Burpengary, Q Australia
                          XS1100E 1978
                          XJ900N 1985
                          Ariel 350 Red Hunter 1949
                          • boyat68
                            • Oct 2007
                            • 358
                            • Virginia
                            Also:
                            Those plastic credit card examples that all the banking instutions send out makes a dandy guage. Just cut the necessary cruciform pattern out, make several at the same time, and one is always available.
