Middle gear warning !
  • datter
    • Feb 2007
    • 78
    • Nova Scotia, Canada
    I was out giving my bike a tune up today before taking my 8 year old out for his very first motorcycle ride. I found the tire pressure was down some, the odd loose bolt here and there, and also that my main engine oil was a bit low. I fixed all that up then this thread came to mind, so I checked my middle and final drive oil... only to find the middle drive oil on the low side.
    I don't imagine it was in any danger of suddenly seizing, but it needed fluid which I might not have otherwise thought to put in there... so thanks for this thread.
    Rebuilt 1981 XS1100 H
    My story
    • egsols
      • Jan 2006
      • 1090
      • Barrie, Ontario, Canada
      Got me thinking too. Checked middle level and its okay but could use a change. Tried to check rear but can't get the plug out. Any problems with rear plug? Should I just use some heat and impact on it?
      Ernie
      • malber
        • Sep 2006
        • 568
        • Belmont, NH
        The PO of my bike gave me some good advice about changing the middle and final gear oil. Part of it is because the drain plug on the final gear is not siezed by spins freely. It doesn't leak however. He said that he used to use a Mity Vac to siphon out the old oil. I just picked one up and will be trying this on the next free maintenance weekend. Works well on the middle gear too due to the positioning of the drain hole right over the center stand cross beam.
        1981 XS1100SH
        • prometheus578
          XS-XJ Super Guru (RESIGNED)
          • Aug 2004
          • 4012
          • Olympia , Wa.
          Egsols,
          Many threads about the rear drive plug.
          Heat, impact, chisel and hammer, etc.
          Once out, coat it with anti-sieze.
          • egsols
            • Jan 2006
            • 1090
            Thanks prom
            Ernie
            • egsols
              • Jan 2006
              • 1090
              Last night used heat, impact, hammer and chisel (in that order) Filler plug is now out. (although it will need a replacment). Oil level is good but due for change.
              Thanks again.
              Ernie
              • Crazcnuk
                • 2980
                • Hinton, AB, Canada
                Mine did the same thing. I swapped it with a drain plug from the engine, as the engine plug has threads right to the head, whereas the rear diff plug, on mine, had a space where there were no threads.
                '05 ST1300
                • egsols
                  • Jan 2006
                  • 1090
                  Funny thing,
                  Got my spare bike parked at a garage at work. Hasn't been riden since 94. As I kinda buggered the head on the screw last night thought I'd give a quick try to pull one off the spare. Put the allen wrench in the hole, tapped on it a fews times to make sure it was in good, put a 15 MM box end on the allen wrench for levarage and pulled. Bolt came out like it was put in yesterday!!!! Who would ave thunk it.
                  Ernie
                  • xsilerating
                    • Dec 2006
                    • 431
                    • Eastern Ontario, Canada
                    I had the same sort of reverse problem as well... no problem removing the rear drive plug , wish it had of been as easy with the oil filter bolt and the oil drain plug that most remove easily !
                    Oh well, better some than none
                    1980 XS11 LG (Diablo)
                    1980 XS11 G (Bagger)
                    1978 XS11 G (White Knight)
                    1978 XS11 G (Skeleton)
                    2016 SS (S.S. Flyer)
                    • jmyers40
                      • 41
                      • Indiana
                      Originally posted by malber
                      It's outlined in the maintenance chapter of Clymer. You use the plastic dipstick that comes with the stock toolkit.
                      About that dipstick, both of mine are gone from the two XS11s I have. Anyone have a detailed photo of one of these? Or possibly a measurement on the fill ines from the bottom of the stick???
                      79 XS1100 Special - slowing breathing life back into it...
                      • jmyers40
                        • 41
                        • Indiana
                        You know how to use the box end of a wrench as extra leverage? I'd suggest using a penetrating oil for a couple days, then add a little extra length to your hex wrench before dusting off the impact. "Patience and WD-40", that's what an old guy I used to work for always said about that sort of thing.
                        • powerram50
                          • 92
                          • portland,oregon
                          i changed out my oil,middle, and final drive lubes as soon as i bought my bike.i new it sat for 3 years before i bought it.
                          81 SH for 300 bucks,work in progress.
                          87 dodge d-50,35's,lockers fr&rr,fun.
                          87 dodge d-50,35's,open diffs,wifes.
                          89 dodge spirit,low 17's 1/4mile w/o turbo.
                          • xsilerating
                            • Dec 2006
                            • 431
                            Instead of penetrating oil or WD-40, I suggest that you use PB Blaster. Worked great for me when I had trouble removing a number of bolts (oil filter; oil drain plug; etc.) and none of the 'other' familiar lubricants did a d@mn thing.
                            Worked every time.
                            • prometheus578
                              • Aug 2004
                              • 4012
                              • Olympia , Wa.
                              Middle drive dip-stick
                              jmyers....
                              they're also still available at Yamaha for a few bucks.. maybe about $6, if I'm not sadly misshapen.
                              • Peter G
                                • 11
                                • Bordom Hampshire UK
                                Just a few thoughts on WD40 clickyclicky
                                Cheers Pete
                                Endeavour to persevere
                                Given up Mr Nicotine, (No Puff Pete )
