shifter
  • shifter
    i have found that the shifter is too close to the foot rest
    i wear boots not enough space to shift comfortably'
    can i move the rest or get a longer shifter.
    Movin On Down The Line.
    Where Ever You Go.
    There You Are.
    '82'xj1100j Maxim
    You mean like this at www.mikesxs.com?
    Jasons Bigfoot Gear Change Lever
    Jasons Bigfoot Gear Change Lever - Do you have feet Larger than the guy that designed the gear lever on your XS ? This extended gear lever for the XS650 will fit better and also improves shifting ! Includes rubber. Fits: 1970-84 650's
    Part #19-6502 $12.00 USD EA.
    Of course you can also reposition the shifter lever clockwise or CCW on the shift shaft to allow more room for your foot under it, depending on what angle you want your foot/toes to be at and still be able to pull up on the lever without overflexing your foot!
      shifter
      i have a xj1100 mabe after i take a motorcycle course it might help
      i could be doing all wrong
      Where Ever You Go.
      There You Are.
      '82'xj1100j Maxim
        xj1100 , XS, same lever.
        So...grandma, what big feet you have
        Most of the time I wear steel toe work boots, size 10.
        No problems.
        mro
          shifter
          do you have the extended shifter?
          Where Ever You Go.
          There You Are.
          '82'xj1100j Maxim
            No
            Reg shifter is just fine for me.
            mro
