Motor missing- solution?
  • sailor202
    XSive(Deceased)
    • Aug 2007
    • 12
    • Rio Vista, Ca.
    79 xs1100 special -- was rebuilt by high school tech shop. Since then have spent tons on trying to find out what is wrong with it. Starts fine, idles fine 0-60 fine, 60-70 coughs and sputters, 70-140 fine. Coughs and sputters both up and down. Have tried new igniter,coil,carbs, am at a loss, need some suggestions. Am looking for a motor to replace it for now, if you've got one for sale, let me know. Glen
    • 5062
    I would check the pickup coil wires under the left engine cover. Remove the cover, pull off the vacuum hose that goes from the ignition cover to the No 2 carb and plug the carb nipply with a piece of hose and a golf tee. Start the bike. Pull the wires that goe to the pickup coils and look for "hour-glassing" which indicates a break in the conductors inside. If there is a bad wire, it will probably kill the engine. There are many tech tips here about repairing the wires...use the search option.
    If the wires are OK, look for problems with the exhaust system, like cracks, crapped-out baffles, or maybe they didn't use crush gaskets at the head pipes.
    If all of the above is good and the carbs are CLEAN, then you can mess with the diaphragm needle settings.
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      How can your motor be missing .. it's way to heavy for someone to run off with
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • 79XS11F
        • 3563
        as per skids .. check out the pick-ups and if they are OK check coils and mid range carb operation.
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • petejw
          • 2269
          • sydney australia
          as above,
          but does it do it consistently,
          or when its only warmed up or when its cold?
          does it do it at cruise or while accelerating up or
          down thru that speed range?
          i wouldnt b changing the motor out just yet,
          have u got good compression, the tranny in good nic,
          other than the trouble ur having is anything else occurring?
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
