ebay heads-up
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    ebay heads-up
    These are Rare.I now have two of these complete S/A's if anyone else is interested in the chain-drive, This unit is an easy swap and you can put a 190-200 tire on. My 1-piece chaindrive housing is almost complete and this is the swingarm I am using (frikin SOLID)....the last set-up like this I won for 400 bucks....JAT
    Item number: 150150376122
    MDRNF
    79F.....Not Stock
  • Mathh
    • Nov 2006
    • 699
    • Beek, Netherlands
    The wheel in the picture is Ducati 748/916/996 and not Triumph however, and has to be modified to suit the Triumph setup as it is off center when used stock
    MV Agusta Brutale 910R '06.
    Yamaha MT-09 Tracer '15 grey.
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      ducati
      Hey Math, do you know how much offset there is in this wheel/SA combo? If it is offset to the left by 15-20mm then that's even better. Good eye, I didn't even see the difference in the manufacturing marks on the pics. I have two of these and they look just like it, tri-spoke swirl...very light too!
      MDRNF
      79F.....Not Stock
      • Mathh
        • Nov 2006
        • 699
        • Beek, Netherlands
        I have both wheels lying around and will measure them up for you if you want me to. Most Ducati wheels however are 5.5 x 17 compared to the Triumphs'6.0 x17. I guess mine is 5.5 also. When I remember correctly the Ducati wheel is more offset to the right.
        I no longer have a Triumph Single Sider S/A however.
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          just checked
          that setup (ducati wheel) and triumph swingarm will work too....would only be able to put on a 180 tire though
          MDRNF
          79F.....Not Stock
          • Mathh
            • Nov 2006
            • 699
            • Beek, Netherlands
            yup: I measured the distance on both wheels from left side of the rim (chain side) to the mounting area in the middle (where the wheel meets the drive, hope you know what I mean)
            ducati 5.5x17 : 101 mm
            triumph 6.0x17: 92 mm
            I also know Triumph uses 5.5x17 wheels too, but I have never had one of those.
