Hello yet again,
Well today should have been the day pete and I finally installed my Wiseco big bore kit.
Pete came over bright and early on his highly polished '81 Special, I had the motor torn down ready for the new pistons to be fitted.
They went on easily then.......
Anyone know of a good substitute for a piston ring compression tool? We were using oversized hose clamps but could only get two pistons fitted into the block, there wasn't enough room to fit the other two between the bottom of the block, the top of the hose clamps and the top of the engine case.
I still haven't located the missing three litres of oil either.
What a waste of a day, it was beautiful too! Mid 20's, no wind and a cloudless sky
You don't need no stinkin' ring compressors!!!!
Oil it up, wrap it around the piston and secure with cable ties (zip ties).
