Ok, the basics. 79 xs11standard. 4-1 exhaust and pod filters, carbs are jetted for both with 42.5 pilots and 140 mains.
I have done everything I can think of, including all of the tips and tricks on the carb faq. I can't get these carbs working.
I tore them down (completely) again the other day and replaced the throttle shaft seals. While they were apart, I blew carb cleaner through the bodies and all orifaces. I re-set the idle air screws to 2 turns out from lightly seated. I inspected the diaphram slides for holes. I put the carbs all back together, and did the pre-sync with a bread twist tie like in the faq. Then I inspected the adapter boots. Still no holes that I can see. I got the carbs re-installed on the bike, and synced the carbs with a mercury carb stick.
All 4 are at 18 inches, idles great, and set the air screws by ear per the carb tricks guide. Re-set the sync, and all is well. Got on to ride, and right out of the driveway, it starts stuttering and lean popping through the air filters. I am jetted for pod filters and 4-1 exhaust. 42.5 pilot jet and 140 mains. Ride it for about 25 miles (to work) and let it sit for a few hours, then I turn the air screws in a 1/4 turn and start it up. Sounds good. Leave work and it is rich popping and stuttering through the exhaust.
All of this popping (lean and rich) happens from just off idle to about 2500 then it picks up and runs fantastic.
Get home, and don't touch anything. Next day, get on it, and it is lean popping again through the intake. Ride to work, stop at a gas station and go inside for less than 5 minutes. Come back out and bike runs perfect with no low end issues at all.
Remember, all my problems are from idle (1000 or so) to 2500 or so. Take off from a stop light about 2 miles from gas station and it starts popping from intake and exhaust, bucking and stuttering and crapping out. Pin the throttle and it stutters a little more then hits hard and tries to pull the front end.
I am absolutely at a loss. I think there is something wrong with these carbs. Anyone have a set that I can re-build? Or is there a set of smooth bore performance carbs on the market for the xs11?
Thanks
Very Frustrated Grimace.
Thanks
