My Kingdom for a valve spring compressor!
  • karl
    • Jul 2007
    • 7
    • Edmonton, AB
    Hi All,
    I've recently aquired a '79 XS11 Special. Cylinder #1 was blowing blue, looks like the valve stem oil seals (compression was good - 135/130/135/140.)
    Ordered the seal/head gasket kit from PNM, got the head off with no problem, but I'm having the hardest time finding a valve spring compressor that will fit. I've tried snap-on and partsource, but their spring compressors won't fit.
    None of the Yamaha (or other) dealers I talked to will touch this (two said to talk to them once the snow flies, but I'd like to ride it this year.)
    So - does anyone know where to find a valve spring compressor near Edmonton, Canada?
    TIA
    -Karl
    XS1100 SF
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    HERE's how I did it. Look near the bottom of the page.
    I used a piece of 3/4" pvc with a notch (to fish the keepers out with a magnet). I used the drill press as the compresser. Rags balled-up under the valves held them in place.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • karl
      • Jul 2007
      • 7
      • Edmonton, AB
      Thanks, Pat - although I don't have a drill press I'll keep that in mind if I can't get a 'real' one.
      Just curious - how easy was it to replace the keepers with that rig?
      XS1100 SF
        Hey Karl,
        In the tech tips, repairs, engine, you'll find THIS TIP that Ken Talbot posted a while back about what he used.
        I found a nice 8" C clamp, and took some 1" diameter metal pipe, about 3" long, cut a 1" slot/wedge out of it, not quite 180 degrees, more like 120 so the remaining amount would be stable against the valve spring cap, and it allows easier access to the keepers for both removal and re-installation. Put the solid foot of the C clamp against the valve head, used the screw portion with the pipe to compress the springs! If I had my welder at the time, I would have tacked the pipe to the wobbly end of the clamp, but you might be able to use duct tape or such to keep it stiff!
        • karl
          • Jul 2007
          • 7
          • Edmonton, AB
          Yeah, I'd read that, but discounted it as I'd like to be able to put it back together, too
          Thanks - that looks like what I might end up doing - although I'm wondering if Pat's suggestion of PVC might be 'safer'. There's already a fair number of scratches around the top of the lifters, where it looks like the PO had 'fun' replacing the valve shims.
          XS1100 SF
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            I got my valve spring compressor at "princess auto". it is for small engines and was not very costly at all. The part that is supposed to sit perfectly on the top of the spring is a little small but it works well I have done 3 top end jobs with it so far. I would if I were you try a search on e-bay. There's lots and lots of tools on e-bay
            edit here's a search result link 2nd one down is just like mine.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • Mathh
              • Nov 2006
              • 699
              • Beek, Netherlands
              A friend of mine hand built one himself. With it we changed the valve stem oil seals with the engine still in the frame.
              The device consists of two wing nuts screwing in a modified cap (with a hole) over the existing springs. With a J-like tool the valve is kept in its place. When screwed in deep enough the two half moons fall apart and everything can be taken out. With special cut up and rewelded pliers the seal could be removed easily. The wing nut device has multiple mounting holes so it can be used for all valves.
              Here are some pics:
              MV Agusta Brutale 910R '06.
              Yamaha MT-09 Tracer '15 grey.
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                I used a piece of 3/4" diameter hard copper pipe and a large C-clamp similar to what Pat Kelly did. I made a jig out of 2x4's that held the c-clamp on its back and made a place for the head to rest so the valve was in line with the clamp. This allowed use of both hands to work the clamp and retrieve the keepers. Had all 8 valves out and parts segmented in an old egg carton in about 15 minutes.
                Mike Giroir
                79 XS-1100 Special
                  That is pretty ingenious. It is no good for lapping the valves or other such work, but for replacing those seals it looks like the cats meow!
                    Like many here I just modified an 8" C clamp. I have several spare parts around, so not everyone can do this, but I drilled a hole in the center of a shim bucket (Dang hard metal) and then ground the foot of the C clamp to a small half-moon shape. The bottom foot of the clamp fits right against the valve face. Just use that bucket in each valve.. screw the clamp down and the keepers fall right off the valve.
                    • prometheus578
                      XS-XJ Super Guru (RESIGNED)
                      • Aug 2004
                      • 4012
                      • Olympia , Wa.
                      &quot;That's pretty clever!&quot;
                      Hey Mathh,
                      Buy your friend a beer... on me.
                      (well, you buy him the beer... but tell him it was from me.)
                      • 79XS11F
                        • 3563
                        There's lots of proof in this thread that where's there's a will ... there's a way. What even method you use just be careful not to damage the walls of the bucket wells and DON'T MIX UP THE BUCKETS !!!
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • prometheus578
                          • Aug 2004
                          • 4012
                          • Olympia , Wa.
                          &quot;An up and coming...&quot;
                          Two more, 79XS11F!
                          • Mathh
                            • Nov 2006
                            • 699
                            • Beek, Netherlands
                            Re: &quot;That's pretty clever!&quot;
                            Originally posted by prometheus578
                            Hey Mathh,
                            heheh, I will !
                            Don't try to copy this, I think he patented it worldwide
                            • karl
                              • Jul 2007
                              • 7
                              • Edmonton, AB
                              Thanks for all the replies.
                              I took Rob's advice, and went to princess auto - lo and behold, they had one that looks just about perfect - cost was good too, $50.
                              XS1100 SF
