Unfortunately(sp?) it seems my bike is only making 63 peak horses. I believe that is low for even stock.... right? Dude says I need some more work on my carbs. Whats stock HP around 90 ?
Anyways I also found out are bikes are faster than a 03 honda shadow sabre 1100. Little bit a good news.
I HATE CARBS. I have had problems since the beginning. Thank I am gonna do a complete tear down and cleansing again. Last week before the Dyno I had them Synced at a shop, but I still have low RPM issues. Unless everyones bike doesn't really get it untill after 3K rpms or so. However I know that is not the case.Whats the consensus? Is my problem carbs, or possibly exhaust/intake setup? I am running Pod filters with TCs velocity stacks, 45 pilots, and 145 mains, I am at 2 1/2 turns out on my mixture screws( when I did the sync we pulled the plugs and the tips were white sitting at 1 1/2 turns out). I am also running open headers with a bolt and washer style baffle(to create some back pressure) . Problems are sluggish up to around 3K rpms, and when it gets warmed up it backfires on deceleration, and also has problems sometimes while just cruising(sputters sometimes).
Need help, what should I do???????
