Carbs cleaned and new Mains installed?
  • Shack
    • Aug 2002
    • 118
    • Texas, Nacogdoches
    Hello Again,
    I was at the YAMMY dealer and the main Mechanic was at the counter parts. I picked up my new main jets and asked for some pilot jets...Main jets 147.5 and He said I wouldn't need pilots..just put new mains and it would be OK..I am putting on new individule filters and am I have read the xs files and they recommend going up in the pilot jets.. I wasn't able to get new pilots..they didn't have them>>>What should I do..chance the mechanics advice or what?????? Let me know your thoughts.
    Thanks
    Shack
    Shack
    79 xs11 Special "SOLD Aug 26 2003"
    2001 GSF K 1200 Bandit "BIG 12"
    Oct 02
    2001 GSF Naked + Black 1200 Dec 03
    3176 miles
  • tsears
    • 70
    • Daly City, Ca.
    no pilots carbs
    Hi,
    I have a bank of these 'no pilots' carbs on my '80 SG. They are NOT the stock carbs, and the pilots are capped off with screw on caps. Consequently, I believe, the mains are quite large, mine are 145's. I tried running it with the pilot holes uncapped, the stock (42.5) pilots, and a variety of mains from 110 to 145. All situations failed miserably, so I recapped the pilot holes and went back to the 145's. Runs great like that and produces good tan plug color.
    Good luck,
    Tim
    80 XS11 Special
    • crunchbird
      • 118
      • Tigard OR
      Those capped off pilots are fed by a little passage coming over from the main jet. You can still play the pilot jetsize game but you need the caps on. If you are so inclined.
      David Browne
      XS11SG Crunchbird
      XS500E
      • Shack
        • Aug 2002
        • 118
        Thanx,
        My 79 has removable pilots but Yammy mech said usually no need to change them...Any of ya with a 79 or experience help...I don/t want to lean the bike out????/ Will it be alright to put the carbs on and try it???? Or with the indi filters will I hurt the engine???? Please let me know..
        Shack
        Shack
        Oct 02
        3176 miles
          I am pretty sure that the E, F, and SF have a passage between the main bore and the pilot bore. I have SH and H carbs that do not have the interconnecting passages. The pilots are also open to the gasoline without plugs. The screw-on plus were stock on the older carbies. That is NOT to say that Yamaha wouldn't have used up the surplus carbs that were on hand to produce the 80 models...
