Will one off a XS 750 Triple work on my xs1100 special 1980?
cam adjuster ?
Tags: None
Hey BikeNutt,
Don't believe so, they are in different positions, 11 in front, the 750 in rear, and they have totally different part numbers for the main parts:
However, if you'll notice, the BOLT is the same part number, so you should be able to use "IT", but not the whole tensioner assembly! HTH?750
1J7-12217-00-00 ROD, CHAIN TENSIONER 1
18 90501-16417-00 SPRING, COMPRESSION 1
19 1J7-12213-00-00 GASKET, CHAIN TENSIONER CASE 1
20 2G2-12212-00-00 CASE, CHAIN TENSIONER
90109-08442-00 BOLT
1100
2H7-12217-01-00 ROD, CHAIN TENSIONER 1
12 90501-16493-00 SPRING, COMPRESSION 1
13 2H7-12213-00-00 GASKET, TENSIONER CASE 1
14 2H7-12212-01-00 CASE, CHAIN TENSIONER
90109-08442-00 BOLT
T.C.T. C. Gresham
