Well I got the stuck clutch free by putting the front tire against the wall and knockin it into first. Took two trys. Figured Id give that a couple trys before taking it apart. Now the idle is a different story. Capped off the vacumn barbs and it would only run about half throttle even at WOT. Uncapped one of them and it zoomed right back up. Capped it again and it ran normal. Dont know why but whatever. Anyways, its alot closer now but it still wont idle even with the pilot screws 3 1/2 turns out. It seems to stumble down low then about half throttle she pulls HARD. Im assuming I need to go up one size from stock on the pilots due to the low end stumble.
80XS11G (heavily modified) "Snot Rokkit"
Deuces Wild
Custom Paint & Body
1200 N. Wall Sreet
Calhoun, GA 30701
770-608-3779
