My clutch experience.
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Hello all,
    Recently my clutch started slipping with 32K miles on it. After reading many post here I decided to replace the frictions and the springs and hold the extra steel plate option open in case I needed that. So I ordered a set of EBC friction plates and a set of HD springs and a new steel plate.
    The old clutch plates looked in good shape but did exibit some wear and two of the steel plates had a couple of small burnish marks on them. The new springs were about 1/16" taller than the OEM springs and when I put the new friction plates together with the steels the pack was about 1/32" thicker than the stack with the OEM plates. So I decided not to install the extra steel at this time.
    I put the new friction plates in oil the night before to let them soak. I used a piece of glass to check for flatness of the steels and they were all OK. Then I used some 220 grit wet/dry sand paper to tooth the surface the steel plates. After that I cleaned up all the parts. Everything looked new. It all went back together easily and I took care when tightening the star plate that the springs were in the correct positions. I took advantage of the situation to clean the oil level glass and to polish the cover on my buffing wheel. The whole job took about 2 hours.
    After everything was finished and the clutch and cable adjusted, I noticed the lever had a much more firm feel to it than before. Also, I noticed that the travel of the lever felt more full than before. Road test time! I noticed from the start that the clutch engaged extremely smooth, with no hint of a chatter. I rode about 30 miles to seat everything in before I gave it the WOT test. What a difference! All the way up to redline without a hint of slippage.
    Everything was right around $100.00 from BikeBandit.
    Mike Giroir
    79 XS-1100 Special
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    with a pointer torque wrench ( i don't trust my clicker wrench i broke some bolts s without clicking) it came to around 120.00 for me i won a complete barnett getup on ebay, i took me 5 hours, and the right foot peg got it the way.
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • TADracer
      • 1417
      Mason,
      Right foot peg does get inthe way. I took the motor through bolt out and removed the peg and just slipped the bolt back in. After I had the clutch case back on I slipped the bolt out and put the peg back in place then torqued the bolt to specs. It was easier than working around the foot peg.
      I have put a few more miles on and I gotta tell you, the new clutch makes my machine feel like a completely different bike. It is so smooth compared to the worn OEM setup.
      Mike Giroir
      79 XS-1100 Special
