Ok what the heck is it...??
  • scott0757
    • Jun 2007
    • 130
    • Syracuse, NY
    That's a leaky cam chain tensioner! (Crankcase oil film with dirt). There's actually an adjuster nut and bolt under that crud!
    Past Rides:
    1969 OSSA 250 Pioneer
    1979 XS650 Special
    1978 Honda CB750K
    Current: 1980 XS1100SG
      • 7766
      Darrek,
      That picture is of the cam chain adjuster. It looks as if it needs to be cleaned and used.
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        Is it me or are you missing a cylinder or two there?
        • 79XS11F
          • Jul 2006
          • 3563
          • Ottawa, Ont. Canada
          I am sure that the pic that Ken posted of that little 1/2 dome is where the engine is supported for assembly. there is one in the back as well and there is little doubt that the engine would be perfectly balanced if picked up at those 2 locations. At the factory they don't wrestle these engines into the frames like we do. The engine is placed by machinery and that machinery picks the engine up at those locations.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            Darrek:
            Thats your cam chain tensioner. By the looks of it you may have a leak around the plastic plug at the forwared end. If you remove it, clean plug and bore, and replace plug after putting some black RTV sealant around it it your engine will stay cleaner.
            To the left side of the part, scrape off the dirt and you will find a jam nut and short bolt. Nut takes a 12 mm wrench, bolt takes a 10mm IIRC. Your cam chain should be adjusted every 3K miles or so, looks like this has not been done in a while. Look at this Tech Tip for instructions on how to adjust the cam chain and also get other information about the cam chain and tensioner:
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
            • Ken Talbot
              • 4251
              • Revelstoke, BC
              Originally posted by concours
              Now, what the heck is with the pipe nipple and couplings on your motor mount?
              Another adaptation - a way to use a low-budget engine stand...
              Ken Talbot
                • 5062
                That picture is a keeper!
                • JWSanders
                  • 879
                  • White House, TN
                  Ken, that's an interesting color. Going for the olive drab/military look? Or is that just primer
                  Slick mount, btw.
                  80 XS1100SG
                  81 XS400SH
                  Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
                  A Few Animations I've Made
                  • firecrackerboom
                    • Jul 2007
                    • 81
                    • South Dakota
                    those instructions on adjusting the cam chain are very vague... can anybody help me out maybe with pictures or more specific instructions? thanks.
                    1979 Eleven Special - 26,000 miles.
                    • GtrMn
                      • May 2003
                      • 248
                      • Springfield Va
                      The "lock nut" is the 12mm...loosen it first...the other is a 10mm loosen it..then tighten it back to torque specs. Then tighten the 12mm back to torque specs..just did mine today. Make sure first that you spin the 19mm bolt in the crank end clock wise a couple time first...It's under the left side cover where your pickup coils are..Turn it until it aligns with the "C" mark. Pull the plugs to make it much easier to turn the engine. Hope this helps.
                      XS 1100 LG
                        • 5062
                        0. put the bike on the center stand
                        1. loosen spark plugs to make turning the crank easier.
                        2. remove the left side timing cover (4 bolts)
                        3. turn the crank in the clockwise direction like the arrow on the plate, by using a 19mm open end wrench or a 3/4 inch wrench on the square "nut" on the timing plate. Make it two full turns and stop on the C mark without passing it.
                        4. loosen the nut on the tensioner, then loosen the bolt.
                        5. tighten the bolt to spec using a baby torque wrench. Do NOT overtighten. Never use a tensioner with stripped threads.
                        6. tighten the nut.
                        7. tighten spark plugs
                        8. start bike and listen to the chain. This is also a good time to check out the pick-up wires
                        9. button on the timing cover.
                        • Ken Talbot
                          • 4251
                          • Revelstoke, BC
                          Originally posted by JWSanders
                          Ken, that's an interesting color. Or is that just primer
                          You got it. That's a good quality self-etching primer. Since then, it has been sprayed satin black, to match the frame and all of the powder coated parts. Going for a total black-out look for this one.
                          Ken Talbot
                          • JWSanders
                            • 879
                            • White House, TN
                            Nice! Can't wait to see the finished product!
                            80 XS1100SG
                            81 XS400SH
                            • Hammerhead1st
                              XStremely XSive(Deceased)
                              • Jul 2007
                              • 330
                              • Lawrencvile, GA
                              FIRECRACKERBOOM has it!!!
                              Thats the part! He's got it...I'll read on and see if anyone found an answer...
                              "Rat Rod"
                              79 XS1100 Standard
                              87 VMAX cans
                              Cheap Japanese Tires
                              Cobalt Blue Rattle Can Paint
                              Custom Lighting on a Budget
                              Perry Center Fire Department
                              Perry Emergency Ambulance
                              "If we don't do it, who will?"
                              Some people have one of those days, I have one of those lives...
                              • Hammerhead1st
                                • Jul 2007
                                • 330
                                • Lawrencvile, GA
                                THanks, guys...
                                THere's a TON of great information here. Thanks for replying with such detailed answers
                                "Rat Rod"
                                79 XS1100 Standard
                                87 VMAX cans
