Ok what the heck is it...??
  • Ok what the heck is it...??
    On the front of the engine, down low between cylinders 2 and 3, slightly just above the oil filter, there's a thing sticking out and it's covered in oil funk..only way I can describe it is a gold-colored nipple. almost resembles a speed sensor or something like a pneumatic oil changing chuck, something you'd plug the drain line to for a quick oil change.
    SOOOOOO
    What is it?
    "Rat Rod"
    79 XS1100 Standard
    87 VMAX cans
    Cheap Japanese Tires
    Cobalt Blue Rattle Can Paint
    Custom Lighting on a Budget
    Perry Center Fire Department
    Perry Emergency Ambulance
    "If we don't do it, who will?"
    Some people have one of those days, I have one of those lives...
    Do you mean the cam chain tensioner?
    1979XS100SF
    2007 Dyna wide glide
    Too many dodge trucks to list!
      I dont think so
      It sits way low on the front of the engine. Doesnt appear to have anything to do with the cam chain
      "Rat Rod"
      79 XS1100 Standard
      87 VMAX cans
        Hey HammerHead,
        You may have already found your answer by looking at the parts fiches, but since yours is a Standard, and by the wear marks around the frame above the exhaust pipes, it looks like it might have had a full Fairing at one time, and quite often folks put on an oil cooler as well.
        So...IF what you are talking about is directly above the Oil Filter Cup, then it could be an oil cooler adapter plate with the oil lines capped off??
        But if you're talking half way up the head, then it's probably the cam chain tensioner, but I think you already know about that.
        Now that you know how to post photos, you could show us what you're talking about, would make it more easy for us to help!
          Your going to have to post a photo? I have never seen anything like what you describing on any XS11 engine. I would think that if it was a oil hose nipple that has been capped off there would be 2 of them in that area. One in and one out. The only thing down there on my engine is the horizontal pin catch that is used to hold the balanced engine and place it in the frame during the building of the bike. There's one at the back of the engine as well for the same purpose.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
            I think he is talking about that "tumor" just above the frame cross member, below the cam tensioner and the motor mount shaft/bolt.
            Is it from the milling/casting process? Is it part of the fairing support?
            greg
            Gone but never Forgotten:
            1980 XS11SG - "Scorpion"
            Current:
            2006 Yamaha FJR1300A - "Orion"
            2007 Honda CBR600RR - "Twitch"
            "Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body; but rather to skid on broadside, thoroughly used up, totally worn out and loudly proclaiming:
            WOW - What a ride!
              Ok, will get pics soon...
              Couldnt find it on the fiches, so it's still a quandry...could be the cam chain tensioner but still not sure. Will bump this one when I get a pic
              "Rat Rod"
              79 XS1100 Standard
              87 VMAX cans
                Good question. I believe this is a shot of the mystery 'part':
                And here's a shot looking up at it from slightly below:
                The underside of the bump is bored out part way at a fairly large diameter, then further at a smaller diameter. None of it is threaded, and it does not go anywhere. It has nothing to do with the oil coolers I have on our Standards, not does it have anything to do with fairings or fairing mounts. It is found on both Standard and Special blocks.
                I have absolutely no idea what this is for.
                Ken Talbot
                  Could it be a part of the casting used to hold/manuver the engine at the manufacturer? That's my guess.
                  Pat Kelly
                  <p-lkelly@sbcglobal.net>
                  1978 XS1100E (The Force)
                  1980 XS1100LG (The Dark Side)
                  1999 Suburban (The Ship)
                  1994 Dodge Spirit (Son #1)
                  1968 F100 (Valentine)
                    I'm surprised at all of you!&quot;
                    If you hang a Gremlin Bell from the engine motor mount bar above it, you'll catch lots of those little SOBs as they run in and out.
                      Or it could be a pry spot when splitting the cases
                      79 XS1100 modified standard
                      straight pipe 4-2 exhaust
                      Owned 83 Honda V65 Magna
                      Owned 02 Vstar 650 classic
                      owned 85 Honda Shadow VT 700C
                        Pry spot? There are no pry spots! Ok, well maybe a couple, but I vote for the thing being related to the casting process.
                        • #13
                          It's a cast in boss that has a precision hole bored in it, it's used to locate the upper case half onto a fixture for machining subsequent features. MANY engines have them...
                          Now, what the heck is with the pipe nipple and couplings on your motor mount?
                          • #14
                            Could that be another Talbot innovation in the form of solid motor mount?
                            • #15
                              is it this thing? i have been wondering about that too.
                              thanks for your guys' help
                              Darrek
                              1979 Eleven Special - 26,000 miles.
