Throttle cable Re and Re
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Could someone give me a point by point to replace my throttle cable . Thanks
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
  • pggg
    • 1609
    • NZ
    Remove petrol tank, dismantle switch/throttle housing, un-notch the cable end from within, un-notch the cable from the carb linkage
    • mro
      • 4276
      • Hayward, California
      Hey pggg..we got fuel or gas tanks here
      Pay attension to how the cable is routed so you can put the next one in the same way.
      Get it "wrong" and it can give you a little surprise when you turn the bars all the way.
      ______________
      Two screws hold right control together.
      After there out the control can be split, carefull not to pull starter button wires out when opening control. When you get it open it's obvious how to R & R cable. (obvious to me at least )
      mro
