Instead of opening several threads along the way here, I'll just post whatever problems I have here.
OK... next problem. I have never tried to get the gears out without splitting the cases. Here's where I'm at so far.
How do I get the shift forks out of the way to be able to pull the gears out? In the second pic, as you're looking at the motor, the fork on the left side came out, but the other two don't seem to have room to. I have removed the shaft that those forks slide on. Help please??
That rotates the shift drum so that you can position the shift forks back down into the engine.
it would definately be easier of you could just buy them.
