I have a l979 XS1100 Special. I twisted off the drain plug on the left hand side of the motor right below the timing cover. Does anyone have one?
help oil drain plug
Tags: None
Hey Bear,
IF you're talking about the bolt at the bottom of this picture, then you've broken the oil galley plug bolt, it's not available from Yamaha anymore!
However, if you're talking about the nut partially showing in the bottom right of this picture, then THAT IS the oil pan bolt, and you should be able to match one up at your local auto parts store!
If the first one, then you'll need to drill it out, and then again try to match one up at the auto parts store, unless someone has one from a donor engine they can get to you? Good Luck!
T.C.T. C. Gresham
How nature points out the folly of men! -
You guys when will you just ask me directly to send you that rare piece that can only come from a donor engine I have several. Pm if you need it please . andreasComment
oil drain
yes its the oil galley plug bolt it has a o ring on it got the other end out of the bike jest took it out with my fingerComment
