need X-tra lighting
  • dodjh
    • Nov 2006
    • 124
    • Buck Snort, Mississippi
    need X-tra lighting
    Fellows I just don't have enough night light. I've read alot of
    the posts on what you can do to get more light---but there has
    to be a simpler way to run two more front lights. From what I
    gather from the posts its one hell of a job to do it and you still
    can have battery drain! The standard headlight just doesn't
    cover enough area to safely drive at night. ???????????
    dodjh
    Semper Fidelis to my brothers serving on foreign hostile soil
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    hid, have i on my 11. and i is 4 time brighter go for it go to fleabay.
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
      • 7832
      dodjh,
      What Mason is trying to say is get the H.I.D. light kit from ebay. It will give you MUCH more light, and uses about 1/2 the amps of a 55 Watt headlamp. It will take a little work to put it in, but it should be worth it.
      • dodjh
        • Nov 2006
        • 124
        X-tra lighting
        DiverRay,
        Are you referring to a kit or a system.
        Thanks,
        dodjh
          Another Possibility!
          Hey Dod,
          Aside from trying to add Extra lights, IF you're using the OEM headlight lens, then you might want to look into a CLEAR LENS conversion? MikesXS sells these lenses/reflectors for the headlight assembly, and then you can get an 80/100 watt bulb from JCW for it, and you may find that it is bright enough without having to actually run wires, and add brackets and switches and such!? JAT!
          • dodjh
            • Nov 2006
            • 124
            X-tra lighting
            Thanks T.C.---I'd like to keep it as simple as possible and that
            seems to be a proper way to address it.
            dodjh
