Differences
  • rman
    • 228
    • Stroudsbug PA
    Differences
    Hello forum,
    A question for all of you knowledgeable ones.
    I was looking at a parts bike that is an 80G. I may be able to get the bike for about 200. Will most of the parts work on my 79F?
    I am interested in the brakes, exhaust, forks, carbs. What are the major differences between a 79F and 80G. Would this be a good price for a parts bike? I am told the engine works well but the bike is salvage.
    Any help is greatly appreciated.
    Trying not to offend since Aug 28, 2010
    Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
    Owner of:
    1979 XS1100F (The Pig)
    140 mains
    45 pilot jets
    Floats at 24mm
    Running Rich
    "Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt Romney
    Yeah, nearly everything. I am thinking that the location of the black box and config of the rear fender and seat are the main differences. There might be a diode for the headlight relay built into the harness of the G. The footpeg bracket plates are probably different, so you might have to make a modification to use the pipes. I had to do that when I put 81H ipirs onto the 78E.
    • andreashweiss
      • 951
      brakes same, exhaust same,carbs bs-34 mikuni 78/79 are different than 80/81 bs-34 mikuni so parts will not interchange but the carbs will swap out and work on either bike. Sidecovers may not interchange. Most likely the electrical stuff is the same but you may find the connectors on some may be different,just have you use you plug ins and splice them into other harness if swapping harness. andreas
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        carbs, needle has no adjustments
        other differences are:
        seat
        side panels
        panel braze on's
        no kick start
        tubeless rims for sure
        someone else?
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
          • 7818
          rman,
          For $200, buy it. You can use almost everything from the bike. Big difference is ignition. If you do an engine swap, keep all the ignition parts from the left side of the engine. Everything else is a bolt and go, except the TCI box, rear fender and seat.
          • JWSanders
            • 879
            • White House, TN
            If I could find another for $200 here I'd scoop it up in a heartbeat.
            At the very least, you can get your money back easily on the parts you don't need by selling them on here or Ebay.
            80 XS1100SG
            81 XS400SH
            Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
            A Few Animations I've Made
            • Crazcnuk
              • 2980
              • Hinton, AB, Canada
              80G? PARTS!
              <puts hand up>
              '05 ST1300
                I think Ray's still recovering from his Jet Lag!
                The 80 TCI is the same as the 79, it's the 81 that's totally different, so you can use the TCI as well!
