sticky valve
+ More Options
Posts
  • blackdawg
    • May 2007
    • 87
    • north delta,bc
    sticky valve
    I have the bike runnining ,going to synch the carbs this weekend.I have noticed a sticky valve.You can hear that tick tick sound.I changed the oil.IS there a additive you can add to the oil to smooth this out.OR will i be looking at a head rebuild in the winter.
    BLACKDAWG
    BLACKDAWG
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Have you adjusted the valves?
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      Have you adjusted the timing chain?
      A leaking exhaust gasket at the manifold can make a ticking sound, also, as can the vacuum advance unit if the hose is improperly routed to the manifold instead of the port on #2 carb.
      • scott0757
        • Jun 2007
        • 130
        • Syracuse, NY
        Depending on the year/model, the tick may require a new valve shim as they cannot be adjusted mechanically. They are not hydraulic lifter so oil would have no impact. Look for threads...
        I have a tick also apparenrly in the #4 exhaust location. Use a mechanics stethescope to pinpoint the spot. It starts when the engine gets it warmed up Adjusting the chain tensioiner helped some of the noise, but not the tick!
        Past Rides:
        1969 OSSA 250 Pioneer
        1979 XS650 Special
        1978 Honda CB750K
        Current: 1980 XS1100SG
        • blackdawg
          • May 2007
          • 87
          • north delta,bc
          valve ticking
          just noticed this yesterday, it is something i will be looking at soon.
          BLACKDAWG
          BLACKDAWG
          • blackdawg
            • May 2007
            • 87
            • north delta,bc
            VALVE TICKING
            tHATS FUNNY YOU SAY THAT AS I HAVE NOTICED A SLIGHT LEAK,SO THAT MIGHT BE RELATED .I WILL CHEQUE THE VACUAM HOSE FIRST.JUST TRYING TO GET THIS BIKE TO RUN RIGHT FIRST.
            BLACKDAWG
            • Hammerhead1st
              XStremely XSive(Deceased)
              • Jul 2007
              • 330
              • Lawrencvile, GA
              My number 4 manifold gasket doesn't exist...
              ...and therefore, I get a steady ticking sound from that header. There was a nut missing from the exhaust stud when I got it, so I spun on a quicknut I had laying in the toolbox. Quieted the bike considerably, but the tick is still very evident.It's all I can hear at 70mph, since my helmet is a hand-me-down anddoesn't fit right...the wind rushes in under it and swirls in my ears. Very uncomfortable. New helmet on the list...
              Am hoping I dont have a sticky valve issue myself. I get a one-cylinder miss over 5 grand.
              "Rat Rod"
              79 XS1100 Standard
              87 VMAX cans
              Cheap Japanese Tires
              Cobalt Blue Rattle Can Paint
              Custom Lighting on a Budget
              Perry Center Fire Department
              Perry Emergency Ambulance
              "If we don't do it, who will?"
              Some people have one of those days, I have one of those lives...
              • pggg
                • 1609
                • NZ
                One missing header gasket equals loud clicking and a one cylinder miss over 5 grand...
