I looked on all the threads, i can"t find out how to build the synch tool for 5.00 .The one without the mercury.Can you use a compression tester in place of a air pressure guage ?
building a synch tool
Try this link.
YOu need Vacuum guages, not pressure, and while they will work, they tend to be less accurate.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
syc. gauges
You will need a small modulator valve in the lines,or the gauge needles will jump all over the dials, gauges aren't as go as mercury tubes but they can get the job done,work way better than feeler gauges.Fastmover
lion". SHL
78 XS1100eComment
Vac gauges are very accurate when damped properly, those old clunky merc tubes are obsolete and toxic and forget the various home made contraptions, they're mostly junk, sync each carb by 'eye' properly first. Buy a decent 4-dial gauge set or a compact modern merc unit later.Comment
carb trouble
input guys ,is the clear tubing with oil a good sycro tool.Will this work or should i try something else.There was one i saw that was pcv pipe ,vac guage, and tubes coming out of it.I"M not sure if i saw this from ken talbot ?BLACKDAWGComment
Re: carb trouble
Yes!. I made one ages ago and have my bike tuned to perfection.Originally posted by blackdawg
IMO it is more accurate than vacuum guages as works in a more sensitive manner. Individual vacuum guages do work but they can be dependant on how evenly you close the restictors. If you restrict one too much then that carb will not be allowing as much vacuum to the guage meaning you are adjusting the sync to match the mismatch.
I know that probably doesn't make much sense but it does in my head.
The downsdie of the homemade one I use is it is not very forgiving if the carbs are way out of sync. If one pulls too much too fast you get air bubbles in the line. Never sucked any oil through yet though.
Here's mine.
The smaller the tube, the less fluctuation you get. I use trans fluid in mine.1981 XJ550RH
1978 XS1100E The Wildebeast
1978 XS1100F X Streem
1980 XS1100G (with an E motor)(parts bike)
Jet/Mod Calculator
Speed/Gearing CalculatorComment
HG, yeah you damp all vac gauges till their needles flicker only 2 or 3 mm's, you can slam on a vac-gauge set and balance the carbs within a few minutes no hassles, using only one vac- gauge takes a bit longer, but at about $15 for one gauge it'll likely be cheaper than a home made gadget anyway, but yeah on the tube & oil gadgets, if you can keep the oil levels under control, you're doin' well!Comment
Single vac gauge synk
Hook to intake boots.
Raise fuel tank, put petcocks to prime.
Raising tank gives a little more room.
I use a small piece of 2 X 4.
Hook single gauge to #3 first to get base reading.
Synck #4 to #3
Then check that #3 did not change (the pita of using a single gauge)
Synck #1 to #2
then #2 to #3 (#1 moves when adjusting #2)
Need to recheck em all.
mro
on my single gauge set up I put a small bolt with a hose clamp holding it on the vac hose. Tightening clamp squeezes the vac hose and bolt together pinching the vac hose until needle on gauge settles down enough to read.Comment
different animal. I made the carb sync tool that uses a vac gauge, a pvc tube, lots of vac line and an aquaruim four valve switcher thing from the pet store. It is easy to use and I noticed a big difference in the way the bike ran compared to the bread tie sync. I got my vac gauge from an auto parts store and it was about $15.00. The rest of the parts came from Home Labrynth and the pet store.
this one: http://www.xs11.com/forum/showthread...=&threadid=986
EdLast edited by edgo; 07-23-2007, 04:37 PM.79 XS1100SF
78 YZ400E
81 SR500
79 RM250
77 YZ400D
05 RM250
78 CR 250 Husky w/TT500 motorComment
plenum, diverters, and 4 lines.
you supply vacume gauge and one my rubber line and the plenum stops the gauge from bouncing.
29.95 shipped and half pay pal
Mason 3106666622
sorry the classified ad section broke and wouldn't take the ad, if Topcat or another Moderator can move this great."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400Comment
