Hi Folks,
I bought my first bike from my brother a few weeks back. It is the xj1100j. It has sat for 17 years and I have had my share of challenges. While I may hit more brick walls, but I have one I’m stumped on. A little background: The last time my brother rode it, he just put new tires on. After taking it, he said it had a handling problem, like the bike wanted to tip back and forth. For whatever logic, he got disgusted and just parked it. About 5years later, he got the bug again, started it drove it out of the garage and found he had brake problems. Disgusted again, he parked until I picked it up.
Seeing that the rear brake pads were worn down to nothing, I decided to change them. For worn pads, the caliper was still stiff to pry off. When I put the new pads on the bolt didn’t line up, I can force it on, but will completely lock up the rear wheel and looks out of whack from forcing it.
http://www.flickr.com/photos/10336364@N02/870035454/
I suspect that when the tires were changed that the alignment or positioning of the rear wheel was messed up. I tried to loosen the rear axle pinch bolt and axle nut to try shifting the position
http://www.flickr.com/photos/1033636...n/photostream/
I also checked and adjusted the swing arm.
What gives?
Thanks, Paul
What gives?
Thanks, Paul
. An hour ago I threw on the old pad for the inside position and it was fine. I was thinking the manufacturer flipped the linings in production, but you are more on the mark regarding the left and right side sets. This has to be the answer....or it is the only logical one that makes sense anyways!!!
