Hey Hammer,
You haven't posted any tech requests yet, but I caught your report about solving your low end miss with double insulating the spark plug wires with electrical tape.
I've reread your posts, and checked your Avatar, but can't tell what other mods you may have done to the INTAKE?
You tried a WOT run, but only got to 85mph, what rpm was your max that you could attain? Does it have the stock airbox, or Indy filters? Unless you've swapped out the mains, it shouldn't be running that lean to starve at speed? These machines will run fairly well at varying levels of leanness!
So...if you DO have Indy filters, take them off for a quick test run to see IF you can get the rpms and speed up beyond 85? Some aftermarket "frugal" indy filters have a prominent lip that interferes with the airflow thru the inlet side and chokes the engines down preventing the vacuum slide from rising properly, etc.!
I'll go back and review what year it is, and then "we" can suggest other things to check to get you "up to speed"!![Wink](https://xs11.club/core/images/smilies/wink.png)
Okay, 79 Standard. You have stated that you've done the carbs twice so far. The standard petcock is vacuum actuated. Have you checked the vacuum lines going to it for cracks and leaks which could prevent adequate fuel flow at higher speeds? I don't remember but I think it has a PRIME setting, might try that?
Have you verified that the upper carb VENT T's and the tubes and the airbox(if you have one) are all open and freely flowing AIR, if blocked by crud, can cause carbs to puke, etc.!
Did you verify that the vacuum slides rubber diaphragms didn't have any pinholes, and they were sliding freely, and that the would stay UP when pushed up by hand and finger placed over the top arced intake port on the carb? When you were in the carbs, did you remove the main jet, AND the main nozzle that the jet was screwed into and soaked/cleaned the little aeration ports in it?
Also, now that the plug wires are fixed, have you checked the timing with a light? Does the vacuum advance module pull the timing plate around when suction applied, and does it HOLD when you block off the tube?
![Frown](https://xs11.club/core/images/smilies/frown.png)
