little spring slide diaphram
  • petejw
    • 2269
    • sydney australia
    hey guys
    just a quick question, 81 special,
    does the little spring sit below the clip or above it,
    for the slide diaphram,
    i ask because mine is sitting above the clip wich
    pushes the needle down, ive been helping strayla
    with his bike and noticed his spring sits below the
    clip which pushes the needle up, his bike is a 78 tho.
    thanx in advance.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • Stralya
    • Apr 2006
    • 791
    • 'Blotto Grotto' Wodonga, Victoria, Australia.
    Hey Pete,
    I've sent you an email, it might be helpful.
    Dan.
    Automotive Imbecile.
    Proud owner of 'The Swiftcicle'. (Swifty for short)
    '78E Full Vetter Dresser.
    1196 Big Bore Kit.
    • petejw
      • 2269
      • sydney australia
      just bumping this thread back up again,
      can anyone chime in, i think i have
      it right, just like 2 have it confirmed.
      cheers
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • Do Lee
        • Feb 2003
        • 255
        • Victoria, Texas
        Pete,
        I have multi sets of carbs for the 78,79,80 & 81 XS11's both Standard and Specials. The 78,79 carbs the spring is below the clip and on the 80,81 carbs the spring is above the clip. The only difference in the carbs needles I see is the 78,79 needles have 5 slots for adjustment and the 80,81 needles are fixed. This maybe why the springs are set differently.
        Do'Lee
        XS1100SF "Green Hornet"
        (1) XS1100LG "Midnight Dream" Restoration has begun.
        (2) XS1100LG "Midnight Madness" Waiting to be next
        (5) multi partsters for bobber "Ruby Red II" On the list.
        SR500H "Silver Streak"
        • petejw
          • 2269
          • sydney australia
          Thanx Do Lee,
          just wanted to be sure,
          also just for ur info, mine has the 5 slots
          in the needle as well, i think there must b
          sum slight differences in the carbs from the usa models
          and aus.
          thanx strayla, that info helped as well.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
